ABSOLUTE Back-Jaw Centerline Caliper Series 573-Center-to-Center & Edge-to-Center Types
Series 573
  • Specially designed to measure the distance between two centers or the distance from an edge to center.
  • Provided with jaws on the back of the slider, measurements can be read easily by looking down.
  • Direct reading of pitch measurements is available due to the offset value setting function.
  • With SPC data output.
  • Supplied fitted in wooden case.
Accuracy: Refer to the list of specifications. (excluding quantizing error for digital models)
Resolution: 0.01mm
Length standard*: ABSOLUTE electrostatic capacitance type linear encoder
Max. Response speed: Unlimited
Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
959143: Data hold unit
959149: SPC cable with data switch (1m)
959150: SPC cable with data switch (2m)
Metric
Order No.ImageRangeAccuracy Resolution Mass
573-116-10-10-200mm0.10mm0.01mm482g
573-117-10573-117.jpg10-300mm0.15mm0.01mm578g
573-118-10-10-200mm0.10mm0.01mm485g
573-119-10573-119.jpg10-300mm0.15mm0.01mm581g
