ABSOLUTE Coolant Proof Caliper Series 500 with Dust/Water Protection Conforming to IP67 Level
Series 500
  • Can be used in workshop conditions exposed to coolant, water, dust or oil.
  • Easy to use - no need to wipe or clean the scale.
  • Advanced design styling.
  • Incorporates absolute measurement system.
  • Automatic power-on/off.
  • Data output function.
  • With thumb roller.
Repeatability: 0.01mm / .0005”
Length standard: ABSOLUTE electromagnetic induction
linear encoder
Battery: SR44 (1 pc./2 pcs*), 938882
Battery life: Approx. 5 years under normal use
(1 year: over 300mm / 12” models)
Dust/Water protection level:IP67
0 - 300mm model
Origin-set, Zero-setting, Automatic power on/off, Data
output, inch/mm conversion (inch/mm models)
05CZA624: SPC cable with data switch (1m / 40”)
05CZA625: SPC cable with data switch (2m / 80”)
Order NoImageRange LCD Res Accuracy TypeRemarks
500-752-20*500-752-10.jpg0-6in 0-150mm.0005in 0.01mm±.001inIP67 model
without SPC data output
500-762-20500-762-10.jpg0-6in 0-150mm.0005in 0.01mm±.001inIP67 model-
500-768-20*500-768-10.jpg0-6in 0-150mm.0005in 0.01mm±.001inIP67
.075in rod depth bar
500-769-20500-769-10.jpg0-6in 0-150mm.0005in 0.01mm±.001in-.075in rod depth bar
500-731-20*500-731-10.jpg0-6in 0-150mm.0005in 0.01mm±.001inIP67
carbide-tipped jaws for OD measurement
500-735-20500-735-10.jpg0-6in 0-150mm.0005in 0.01mm±.001in-carbide-tipped jaws for OD measurement
500-733-20*500-733-10.jpg0-6in 0-150mm.0005in 0.01mm±.001inIP67
Carbide-tipped jaws for OD & ID measurement
500-737-20500-737-10.jpg0-6in 0-150mm.0005in 0.01mm±.001in-Carbide-tipped jaws for OD & ID measurement
500-753-20*500-753-10.jpg0-8in 0-200mm.0005in 0.01mm±.001inIP67 model
500-763-20500-763-10.jpg0-8in 0-200mm.0005in 0.01mm±.001inIP67 model-
500-732-20*500-732-10.jpg0-8in 0-200mm.0005in 0.01mm±.001inIP67
500-736-20500-736-10.jpg0-8in 0-200mm.0005in 0.01mm±.001in-carbide-tipped jaws for OD measurement
500-734-20*500-734-10.jpg0-8in 0-200mm.0005in 0.01mm±.001inIP67
500-738-20500-738-10.jpg0-8in 0-200mm.0005in 0.01mm±.001in-Carbide-tipped jaws for OD & ID measurement
500-754-10*500-754-10.jpg0-12in 0-300mm.0005in 0.01mm±.0015inIP67 model
500-764-10500-764-10.jpg0-12in 0-300mm.0005in 0.01mm±.0015inIP67 modelwith SPC output
line drawings videos
