ABSOLUTE Digimatic Caliper Series 500-with Exclusive ABSOLUTE Encode Technology
Series 500
Mitutoyo's absolute Digimatic Caliper is the next generation of electronic calipers.
It keeps track of its origin point once set. Whenever turned on, the large LCD
displays the actual slider position ready to start measurement. No more repeated
zero setting is necessary with the absolute encoder technology, as well as no more
concern for over speed errors.
  • Large and clear LCD readout.
  • The ZERO/ABS key allows the display to be Zero-Set at any slider position along the scale for incremental comparison measurements. This switch will also allow return to the absolute (ABS) coordinate and display of the true position from the origin point (usually jaws-closed point).
  • Data Hold Unit (959143) is optional.
  • Carbide-tipped jaw type calipers are also available.
  • With thumb roller. Except 500-500-10, 500-501-10,500-502-10.
  • Supplied in fitted plastic case. Except 1000mm / 40” supplied in wooden case.
Accuracy: Refer to the list of specifications
Repeatability: 0.01mm / .0005”
Length standard: ABSOLUTE electrostatic capacitance type
linear encoder
Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting, Data output, inch/mm conversion
(inch/mm models ONLY)
959143: Data hold unit
959149: SPC cable with data switch (1m / 40”)
959150: SPC cable with data switch (2m / 80”)
*without SPC data output
Order NoModelImageRangeAccuracy LCD Res Remarks
500-170-30AOS Digimatic Caliper500-170-30.jpg0-4in
0-100mm
±.001in.0005in
0.01mm
.075" Round depth bar
500-195-30*AOS Digimatic Caliper-0-4in
0-100mm
±.001in.0005in
0.01mm
500-171-30AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
500-174-30AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
with OD carbide jaw
500-175-30AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
with OD,ID carbide jaw
500-178-30AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
.075 in rod depth bar
500-196-30*AOS Digimatic Caliper500-196-30.jpg0-6in
0-150mm
±.001in.0005in
0.01mm
500-159-30*AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
Carbide-tipped jaws for OD measurement
500-160-30*AOS Digimatic Caliper-0-6in
0-150mm
±.001in.0005in
0.01mm
Carbide-tipped jaws for OD and ID measurement
500-172-30AOS Digimatic Caliper-0-8in
0-200mm
±.001in.0005in
0.01mm
500-176-30AOS Digimatic Caliper-0-8in
0-200mm
±.001in.0005in
0.01mm
with OD carbide jaw
500-177-30AOS Digimatic Caliper-0-8in
0-200mm
±.001in.0005in
0.01mm
500-197-30*AOS Digimatic Caliper500-197-30.jpg0-8in
0-200mm
±.001in.0005in
0.01mm
500-163-30*AOS Digimatic Caliper500-163-30.jpg0-8in
0-200mm
±.001in.0005in
0.01mm
500-164-30*AOS Digimatic Caliper-0-8in
0-200mm
±.001in.0005in
0.01mm
Carbide OD/ID Jaws
500-173Digimatic Caliper500-173.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-167Digimatic Caliper500-167.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-168Digimatic Caliper500-168.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-193*Digimatic Caliper500-193.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-165*Digimatic Caliper500-165.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-166*Digimatic Caliper500-166.jpg0-12in
0-300mm
±.0015in.0005in
0.01mm
500-505-10Digimatic Caliper500-505-10.jpg0-18in
0-450mm
±.002in.0005in
0.01mm
Without Thumb Roller
500-506-10Digimatic Caliper500-506-10.jpg0-24in
0-600mm
±.002in.0005in
0.01mm
500-507-10Digimatic Caliper500-507-10.jpg0-40in
0-1000mm
±.003in.0005in
0.01mm
line drawings videos literature
