ABSOLUTE Digimatic Caliper Series 551 with Nib Style and Standard Jaws
Series 551
  • The rounded faces of the jaws are ideal for accurate ID (inside diameter) measurement.
  • With SPC output.
  • Supplied in fitted plastic holster in carton.18"/450mm and larger supplied wooden case.
Resolution*: 0.01mm or .0005"/0.01mm
Display*: LCD
Length standard*: ABSOLUTE electrostatic capacitance type linear encoder
Max. response speed*: Unlimited
Battery*: SR44 (1 pc.),938882
Battery life*: Approx. 3.5 years under normal use
Function of Digital Model
Origin-set, Zero-setting, Data output, inch/mm conversion (inch/mm models)
05CZA624:SPC cable with data switch (1m / 40”)
05CZA625:SPC cable with data switch (2m / 80”)
    Order NumberImageRange LCD Resolution Accuracy Remarks
    551-311-10551-311-10.jpg0(.4)-8in 0(10)-200mm.0005in 0.01mm.001inIP67
    551-341-10551-341-10.jpg0(.4)-12in 0(10)-300mm.0005in 0.01mm.002inwith offset/preset function for easy ID measurement IP67
    551-224-10551-224-10.jpg0(.5)-20in 0(20)-500mm.0005in 0.01mm.0025in-
    551-226-10551-226-10.jpg0(.5)-30in 0(20)-750mm.0005in 0.01mm.0025in-
    551-227-10551-227-10.jpg0(1)-40in 0(20)-1000mm.0005in 0.01mm.003in-
