ABSOLUTE Digimatic Depth Gage Series 547
Series 547
  • ABSOLUTE Digimatic Depth Gage can keep track of the origin point once set for the entire life of the battery.
  • Wide probing range is available with the supplied extension rod.
  • Bottom surface of the base is hardened, ground and lapped for highest degree of flatness.
  • With SPC data output.
Resolution*: 0.001mm, 0.01mm, .00005"/0.001mm or .0005”/0.01mm
Flatness of base face: 5µm
Measuring force: 1.4N, 1.5N
Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting,Data output, inch/mm conversion (inch/mm models)
905338: SPC cable (40” / 1m)
905409: SPC cable (80” / 2m)
139167: .5” Extension Rod
301655: 1” Extension Rod
301657: 2” Extension Rod
301659: 4” Extension Rod
303611: 10mm Extension Rod
303612: 20mm Extension Rod
303613: 30mm Extension Rod
303614: 100mm Extension Rod
Base Only(3/8in dia.hole)
902164:2.5in 7217,7237,547-217S,547-257S
902165
4in7218S,7238,547-218S,547-258S
Order NoImageRange Resolution Stroke AccuracyExtension RodsBase WxThicknessBase Flatness
547-217S-0-8in 0-200mm.0005in 0.01mm.5in.001in4pcs.(.5,1,2,4in)2.5x.63in.0002 in
547-218S547-218S.jpg0-8in 0-200mm.0005in 0.01mm.5in.001in4pcs.(.5,1,2,4in)4x.63in.0002 in
547-257S-0-8in 0-200mm.00005in 0.001mm.5in.0003in4pcs.(.5,1,2,4in)2.5x.63in.00008 in
547-258S-0-8in 0-200mm.00005in 0.001mm.5in.0003in4pcs.(.5,1,2,4in)4x.63in.00008 in
