ABSOLUTE Digimatic Height Gage Series 570-with ABSOLUTE Linear Encoder
Series 570
  • Built-in ABSOLUTE linear encoder this encoder eliminates the necessity of setting the reference point at every poweron. It has improved reliability because no over-speed error will occur.
  • Fine-adjustment carriage for smooth movement.
  • Carbide-tipped scriber is provided.
  • With SPC data output.
Display: LCD, 6-digit
Max. response speed: Un limited
Battery life: Approx. 5000 hours under normal use
Origin setting, ABS/INC switching, Presetting, -/+ switching, Data hold, Data output, inch/mm conversion (inch/mm models)
Standard Scriber Provided
Metric models: Carbide-tipped scriber
(900173/905200*) and scriber clamp (901338/05GZA033*)*0 - 1000mm model
Inch/Metric models: Carbide-tipped scriber
(900173/905201*) and scriber clamp (901338/901385*)*0 - 40” model
905338: SPC cable (40” / 1m)
905409: SPC cable (80” / 2m)
953638: Holding bar for test indicator (length: 50mm)
953639: Holding bar for test indicator (length: 2”)
902053: Swivel clamp used with holding bar (metric)
900322: Swivel clamp used with holding bar (inch)
Order NoImageRange AccuracyResolutionMass
570-244570-244.jpg0-8in 0-200mm.001.0005in 0.01mm1.4kg
570-248-0-40in 0-1000mm.003.0005in 0.01mm16.8kg
