ABSOLUTE Digimatic Height Gage Series 570-with ABSOLUTE Linear Encoder.
Series 570
  • Built in ABSOLUTE linear encoderThis encoder eliminates the necessity of setting the reference point at every power-on. It has improved reliability because no over-speed error will occur.
  • Rigid column structure ensures high measuring accuracy.
  • With large smooth slider feed wheel.
  • Carbide-tipped scriber is provided.
  • With SPC data output.
Display: LCD, 6-digit
Max. response speed: Un limited
Battery life: Approx. 20000 hours under normal use
Origin setting, ABS/INC switching,
Power ON/OFF, Data hold, Data output, inch/mm conversion (inch/mm models)
Standard Scriber Provided
Metric models: Carbide-tipped scriber (07GZA000), scriber clamp (05GZA033)
Inch/Metric models: Carbide-tipped scriber
905338: SPC cable (40” / 1m)
905409: SPC cable (80” / 2m)
953638: Holding bar for test indicator (length: 50mm)
953639: Holding bar for test indicator (length: 2”)
902053: Swivel clamp used with holding bar (metric)
900322: Swivel clamp used with holding bar (inch)
Order NoImageRangeAccuracyResolution
570-312570-312.JPG0-12in 0-300mm.0015in.0005in 0.01mm
570-313-0-18in 0-450mm.002in.0005in 0.01mm
570-314570-314.jpg0-24in 0-600mm.002in.0005in 0.01mm
