ABSOLUTE Digimatic Indicator ID-C Series 543-Calculation Type
Series 543
  • The new Calculation-Type Digimatic Indicator features both a Key- Lock and Parameter-Lock to prevent accidental changing of settings during operation.
  • Improved parameter setting software makes easy to set all available parameters, and determine and upload the proper coefficients for calculation. (optional)
  • Fast measurement frequency allows the user to increase the number of readings per second from 10 to 50, allowing higher accuracy measurements of TIR and MAX/MIN.
  • An analog bar provides easy-to-read values when scanning for Max, Min, and TIR Values.
  • The Absolute Digimatic indicator performs internal calculations using the formula Ax+B+Cx-1 (assuming spindle displacement as x) while the specified coefficients A, B and C can be set with respect to the purpose of measurement or dimensions of the fixtures. This unique features allows you to read your measurements directly, without the need for conversions.
Resolution: 12 Steps .00005/.0001/.0005” 0.001/0.01mm
Length standard: ABSOLUTE electrostatic capacitance-typelinear encoder
Measuring force: Refer to the list of specifications
Battery: CR2032 (1 pc.), 05SAA217
Battery life: Approx. 12 months under normal use
IP Rating: Equivalent to IP-42*1
*1 A protection class indication (IP=lnternational Protection) is based on the IEC 60529 /DIN40050 part 1/JIS D0207, C0920. The level indicated is valid only if the output connector cap is installed.
Key Lock, Parameter Lock, PC-USB Input, Analog Bar, FAST measurement frequency, Preset (up to 3 values), Tolerance Judgment , Peak Detection , Calculation, inch/mm conversion (on inch/metric models only), Counting direction switching
Data Output
Alarm: Low voltage, Counting value composition error,Over-flow error, Tolerance limit setting error
905338: Connecting Cable (1m)
905409: Connecting Cable (2m)
21EZA313: Parameter Setting USB Cable
21EZA198: Spindle lifting lever (12.7mm ISO/JIS type)
21EZA199: Spindle lifting lever (12.7mm ASME/AGD type)
21EZA105: Lifting Knob (12.7mm/.5” ISO/JIS Models)
21EZA150: Lifting Knob (12.7mm/.5” ASME/AGD Models)
21EZA197: Lifting Knob (for 25.4/1”mm models)
21EZA200: Lifting Knob (for 50.8/2”mm models)
540774: Spindle lifting cable
Order NoModel ResolutionRangeAccuracy Measuring ForceType
543-341BID-C112RMXB.00001-.05in 0.0002-1mm.5in 12.7mm.00012in1.5N or lessISO/JIS type
Stem Ø8mm
M2.5x0.45 Thread
543-342BID-C112REXB.00001-.05in 0.0002-1mm.5in 12.7mm.00012in1.5N or lessANSI/AGD type
Stem dia 3/8 in
4-48 UNF Thread
543-591BID-C125RMXB.00001-.05in 0.0002-1mm1in 25.4mm.00012in2.0N or lessISO/JIS type
Stem Ø8mm
M2.5x0.45 Thread
543-592BID-C125REXB.00001-.05in 0.0002-1mm1in 25.4mm.00012in2.0N or lessANSI/AGD type
Stem dia 3/8 in
4-48 UNF Thread
543-596BID-C150RMXB.00001-.05in 0.0002-1mm2in 50.8mm.00025in2.3N or lessISO/JIS type
Stem Ø8mm
M2.5x0.45 Thread
543-597BID-C150REXB.00001-.05in 0.0002-1mm2in 50.8mm.00025in2.3N or lessANSI/AGD type
Stem dia 3/8 in
4-48 UNF Thread
line drawings videos
