ABSOLUTE Digimatic Indicator ID-C Series 543-Standard Type
Series 543
  • Similar in size to Series 2 dial indicators.
  • As compact as standard Series 2 dial indicators.
  • Large, easy-to-read LCD.
  • GO/±NG judgment can be performed by setting upper and lower tolerance limits. The judgment result (GO/±NG) can be displayed in full-size characters.
  • The positive/negative count resulting from the spindle’s up/down movement can be toggled.
  • Internal calculations using the simple formula of [F(x)=Ax)] are available
  • Employing the ABSOLUTE linear encoder, the ID-C always displays the spindle "Absolute Position" from the origin at power-on. Also unlimited response speed eliminates over-speed errors.
  • The ID-C indicator face can be rotated 330° to an appropriate angle for easy reading.
  • With SPC data output.
    Resolution: 0.01mm, 0.001mm, .0005"/0.01mm, .0001”/0.001mm or .00005”/0.001mm
    Max. Response speed: Unlimited
    Measuring force: Refer to the list of specifications
    Battery life: Approx. 5,000 hours under normal use
    Dust/Water protection level: IP42 or IP53 (dust-proof type)
    Origin-set/Preset, Zeroset, GO/±NG judgment, Counting direction switching, Power ON/OFF, Data output,inch/mm
    conversion (on inch/metric models only)
    Alarm: Low voltage, Counting value composition error, Over-flow error, Tolerance limit setting error
    905338: SPC cable (40” / 1m)
    905409: SPC cable (80” / 2m)
    21EZA198: Spindle lifting lever (ISO/JIS type)*
    21EZA199: Spindle lifting lever (ANSI/AGD type)*
    21EZA105: Spindle lifting knob(12.7mm/5"ISO/JIS type)**
    21EZA150:Spindle lifting knob(12.7mm/5" ANSI/AGD type)**
    21EZA197:Spindle lifting knob(25.4mm/1",50.8/2" models)
    21EZA200:Spindle lifting knob(50.8mm/2")
    540774: Spindle lifting cable (stroke: 1”/25.4mm)
    02ACA571: Auxiliary spindle spring for 25mm/1” models***
    02ACA773: Auxiliary spindle spring for 50mm/2” models***
    *Can be used on 12mm/.5” models only.
    **Not available for low measuring force models.
Order NoModelImageRange AccuracyContact PointMeasuring ForceResolution *SwitchableTypeRemarks
543-391ID-C112MX543-391.jpg.5in/ 12.7mm.0001inStem Ø 8mm
M2.5x0.45 Thread
Less than
1.5N
*.00005in 0.001mmISO/JIS-
543-391BID-C112MX543-391B.jpg.5in/ 12.7mm.0001inStem Ø 8mm
M2.5x0.45 Thread
Less than
1.5N
543-392ID-C112EXB543-392.jpg.5in/ 12.7mm.0001inStem dia3/8",#4-48 UNF ThreadLess than
1.5N
*.00005in 0.001mmANSI/AGD-
543-392BID-C112EXB543-392B.jpg.5in/ 12.7mm.0001inStem dia3/8",#4-48 UNF ThreadLess than
1.5N
543-395ID-C112CMX543-395.jpg.5in/ 12.7mm.0001inStem ø8mm M2.5x0.45 ThreadLess than
0.4-0.7N
*.00005in 0.001mmANSI/AGDLow measuring force
543-395BID-C112CMX543-395B.jpg.5in/ 12.7mm.0001inStem ø8mm M2.5x0.45 ThreadLess than
0.4-0.7N
543-396ID-C112CEX543-396.jpg.5in/ 12.7mm.0001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.4, 0.6, 0.7N
543-396BID-C112CEX543-396B.jpg.5in/ 12.7mm.0001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.4, 0.6, 0.7N
543-401ID-C1012MX543-401.jpg.5in/ 12.7mm.001inStem Ø 8mm
M2.5x0.45 Thread
Less than
0.9N
.0005in 0.01mmISO/JIS-
543-401BID-C1012MX543-401B.jpg.5in/ 12.7mm.001inStem Ø 8mm
M2.5x0.45 Thread
Less than
0.9N
543-402ID-C1012EX543-402.jpg.5in/ 12.7mm.001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.9N
.0005in 0.01mmANSI/AGD-
543-402BID-C1012EX543-402B.jpg.5in/ 12.7mm.001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.9N
543-405ID-C1012CMX543-405.jpg.5in/ 12.7mm.001inStem ø8mm M2.5x0.45 ThreadLess than
0.2-0.5N
.0005in 0.01mmANSI/AGDLow measuring force
543-405BID-C1012CMX-.5in/ 12.7mm.001inStem ø8mm M2.5x0.45 ThreadLess than
0.2-0.5N
543-406ID-C1012CEX543-406.jpg.5in/ 12.7mm.001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.2, 0.3, 0.4, 0.5N
543-406BID-C1012CEX543-406B.jpg.5in/ 12.7mm.001inStem dia 3 8 in
4-48 UNF Thread
Less than
0.2, 0.3, 0.4, 0.5N
543-471BID-C125MXB543-471B.jpg1in/ 25.4mm0.00012inStem ø8mm M2.5x0.45 ThreadLess than
1.8N
543-472BID-C125EXB543-472B.jpg1in/ 25mm.0001inStem dia 3 8 in
4-48 UNF Thread
Less than
1.8N
543-475BID-C1025MXB-1in/ 25.4mm.001inStem ø8mm M2.5x0.45 ThreadLess than
1.8N
543-476BID-C1025EXB543-476B.jpg1in/ 25mm.001inStem dia 3 8 in
4-48 UNF Thread
Less than
1.8N
543-491BID-C150MXB543-491B.jpg2in/ 50.8mm0.00025inStem ø8mm M2.5x0.45 ThreadLess than
2.3N
543-492BID-C150EXB543-492B.jpg2in/ 50mm.0002inStem dia 3 8 in
4-48 UNF Thread
Less than
2.3N
543-495BID-C1050MXB-2in/ 50.8mm.0016inStem ø8mm M2.5x0.45 ThreadLess than
2.3N
543-496BID-C112CEXB543-496B.jpg2in/ 50mm.0016inStem dia 3 8 in
4-48 UNF Thread
Less than
2.3N
