ABSOLUTE Digimatic Indicator ID-C Series 543-with Max./Min. Value Holding Function
Series 543
  • The new Peak Hold-Type Digimatic Indicator features both a Key-Lock and Parameter-Lock to prevent accidental changing of settings during operation.
  • Parameter setting software makes it even eay to set all available parameters.
  • An analog bar provides easy-to-read values when scanning for Max, Min and TIR Values.
  • The maximum, minimum or runout value can be displayed during measurement.
  • Go/no-go judgment is performed by setting the upper and lower tolerances for max., min. and runout values.
  • High speed sampling ratio of 50 times/s.
  • Employing the ABSOLUTE linear encoder, the Signal ID-C always displays the spindle Absolute Position from the origin when turned on.
    Resolution: 0.001-0.01mm or .00005-.0005”/ 0.001-0.01mm Display: LCD
    Length standard: ABSOLUTE electrostatic capacitance-type linear encoder
    Measuring force: 1.5N or less
    Battery: CR2032 (1 pc.), 05SAA217
    Battery life: Approx. 12 months under normal use
    IP Rating: Equivalent to IP-42*1
    *1 A protection class indication (IP=lnternational Protection) is based on the IEC 60529 /DIN40050 part 1/JIS D0207, C0920. The level indicated is valid only if the output connector cap is installed.
    Key Lock, Parameter Lock, PC-USB Input, Analog Bar, Fast measurement frequency, Preset (up to 3 values), Tolerance Judgment , Peak Detection , Calculation (Ax), inch/mm conversion (on inch/metric models only) Counting direction switching, Data Output Alarm: Low voltage, Counting value composition error, Overflow error, Tolerance limit setting error
    905338: Connecting Cable (1m)
    905409: Connecting Cable (2m)
    21EZA313: Parameter Setting USB Cable
    21EZA198: Spindle lifting lever (12.7mm ISO/JIS type)
    21EZA199: Spindle lifting lever (12.7mm ASME/AGD type)
    21EZA105: Lifting Knob (12.7mm/.5” ISO/JIS models)
    21EZA150: Lifting Knob (12.7mm/.5” ASME/AGD models)
    21EZA197: Lifting Knob (for 25.4/1”mm models)
    21EZA200: Lifting Knob (for 50.8/2”mm models)
    540774: Spindle lifting cable
Order NoModel Lug or Flat-backResolution/SelectableRange TypeAccuracy
543-301ID-C112AMXW/Lug.00005/.0001/.0005in 0.001/0.01mm.5in 12.7mmISO/JIS type
Stem Ø8mm,M2.5x0.45 Thread
.00012in
543-301BID-C112AMXBW/Flat Back.00005/.0001/.0005in 0.001/0.01mm.5in 12.7mmISO/JIS type
Stem ø8mm,M2.5x0.45 Thread
.00012in
543-302ID-C112AEXW/Lug.00005/.0001/.0005in 0.001/0.01mm.5in 12.7mmANSI/AGD type
Stemdia.3/8in 4-48 UNF Thread
.00012in
543-302BID-C112AEXBW/Flat Back.00005/.0001/.0005in 0.001/0.01mm.5in 12.7mmANSI/AGD type
Stem  dia 3/8in 4-48 UNF Thread
.0012in
