ABSOLUTE Digimatic Indicator ID-N/B Series 543-with Dust/Water Protection Conforming to IP66
Series 543
  • Proven ABSOLUTE sensor.
  • Rated to IP66 water- and dust-proofing standard and oil resistance improved.
  • Slim body design is advantageous for multi-point measurements.
  • Improvement in workability with the LCD readout-rotation function.
  • Back plunger design (ID-B).
  • Built-in tolerance judgment function.
  • Switchable resolution.
  • Waterproof data output connector.
  • Built-in hold/preset function
Resolution: 0.01mm, 0.01mm/0.001mm, .0005”/0.01mm
or .0005”/.00005”/0.01mm/0.001mm
Length standard: ABSOLUTE electrostatic capacitance type
linear encoder
Measuring force: 2.5N (2.0N: Back plunger type)
Battery life: Approx. 7000 hours under normal use
Dust/Water protection level: IP66
Zero-setting, Presetting, Direction switching, Tolerance
judgment, Display hold, Data output,
inch/mm conversion (on inch/metric models only)
Alarm: Low voltage, Counting value composition error,
Over-flow error, Tolerance limit setting error
21EZA105: Lifting knob (for ISO/JIS model)
21EZA150: Lifting knob (for AGD model)
21EZA145: Lug (for JIS/ISO model)
21EZA146: Lug (for AGD model)
02ACA376: Rubber boot (for ID-N, NBR)
238774: Rubber boot (for ID-N, silicon)
125317: Rubber boot (for ID-B, NBR)
21EAA212: Rubber boot (for ID-B, silicon)
21EAA194: SPC cable (40” / 1m)
21EAA190: SPC cable (80” / 2m)
21EAA210: Bifurcated connecting cable with zero-setting terminal (40”/1m)
21EAA211: Bifurcated connecting cable with zero-setting terminal (80”/2m)
Order No.ModelImageResolutionRange Accuracy Measuring Force
543-571ID-N1012E543-571.jpg.0008in 0.02mm.5in 12.7mm.0008in 0.02mm2.0N or less
543-576ID-N112E543-576.jpg.00012in 0.003mm.5in 12.7mm.00012in 0.003mm2.0N or less
543-581ID-B1005E543-581.jpg.0005in 0.01mm.22in 5.6mm.0008in 0.02mm2.0N or less
543-586ID-B105E543-586.jpg.0005/.00005in 0.01/0.001mm.22in 5.6mm.00012in 0.003mm2.0N or less
