ABSOLUTE Digimatic Indicator ID-S Series 543-with Simple Design
Series 543
  • After the initial zero-setting with the Origin button, the repeated absolute positioning is no longer necessary over entire batterylife.
  • Unlimited response speed eliminates overspeed errors
  • Similar in size to standard Series 2 dial indicators.
  • SPC data output.
Accuracy: Refer to the list of specifications
Resolution: 0.01mm, 0.001mm, .0005"/0.01mm .0001”/0.001mm or .00005”/0.001mm
Length standard: ABSOLUTE electrostatic capacitance-type linear encoder
Measuring force: Refer to the list of specifications
Battery: SR44 (1 pc.) 938882
Battery life: Approx. 20,000 hours under normal use
Dust/Water protection level: IP42 (IP53: 543-794B,543-795B, 543-796B)
Inspection certificate is included.
Origin-set, Zeroset, Counting direction switching, Power ON/OFF, Data output,
inch/mm conversion (on inch/metric models only)
Alarm: Low voltage, Counting value composition error,Over-flow error
905338: SPC cable (40”/1m)
905409: SPC cable (80”/2m)
21EZA198: Spindle lifting lever (ISO/JIS type)
21EZA199: Spindle lifting lever (ANSI/AGD type)
540774: Spindle lifting cable (stroke: .4” / 10mm)
21EZA105 Lifting knob (mm)
21EZA150 Lifting knob (inch)
125317: Spare rubber boot (for dust-proof type)
Order NoModel NoImageResoRange AccuracyStem DIAForceContact Point
543-782ID-S1012MX543-782.jpg.0005in 0.01mm.5in 12.7mm.0008in5/16in2.0N or lessM2.5x0.45 Thread
543-782BID-S1012MBXID-SX_543-782B.jpg.0005in 0.01mm.5in 12.7mm.0008in5/16in2.0N or lessM2.5x0.45 Thread
543-783ID-S1012E543-783.jpg.0005in 0.01mm.5in 12.7mm.0008in3/8in2.0N or less4-48 UNF Thread
543-783BID-S1012EB543-783B.jpg.0005in 0.01mm.5in 12.7mm.0008in3/8in2.0N or less4-48 UNF Thread
543-791ID-S112MX543-791.jpg.00005in 0.001mm.5in 12.7mm.00012in5/16in2.0N or lessM2.5x0.45 Thread
543-791BID-S112MBX543-791B.jpg.00005in 0.001mm.5in 12.7mm.00012in5/16in2.0N or lessM2.5x0.45 Thread
543-792ID-S112EX543-792.jpg.00005in 0.001mm.5in 12.7mm.00012in3/8in2.0N or less4-48 UNF Thread
543-792BID-S112EBX543-792B.jpg.00005in 0.001mm.5in 12.7mm.00012in3/8in2.0N or less4-48 UNF Thread
543-793ID-S112TX543-793.jpg.0001in 0.001mm.5in 12.7mm.00012in3/8in2.0N or less4-48 UNF Thread
543-793BID-S112TBX543-793B.jpg.0001in 0.001mm.5in 12.7mm.00012in3/8in2.0N or less4-48 UNF Thread
543-795ID-S112PMX-.00005in 0.001mm.5in 12.7mm.00012in5/16in2.5N or lessM2.5x0.45 Thread
543-795BID-S112PMBX-.00005in 0.001mm.5in 12.7mm.00012in5/16in2.5N or lessM2.5x0.45 Thread
543-796ID-S112PEX-.00005in 0.001mm.5in 12.7mm.00012in3/8in2.5N or less4-48 UNF Thread
543-796BID-S112PEBX-.00005in 0.001mm.5in 12.7mm.00012in3/8in2.5N or less4-48 UNF Thread
line drawings product manuals videos
