ABSOLUTE Digimatic Indicator ID-U Series 575-with Slim and Simple Design
Series 575
  • Slim type digital indicator with low price.
  • Large LCD and simple key operation.
  • After the initial origin setting, the ID-U no longer needs absolute positioning over the entire battery life; the origin is remembered even after power-off.
  • Ideal for installation into measuring devices because of it’s compact design and long battery life.
  • Employing the ABSOLUTE linear encoder, the ID-U always displays the spindle "Absolute Position" from the origin at power-on. Also unlimited response speed eliminates over-speed errors.
  • Flat back type only no option for backs.
  • SPC data output.
    Measuring force: Refer to the list of specifications
    Battery life: Approx. 20,000 hours under normal use
    Dust/Water protection level: IP42
    Origin-set, Zeroset, Counting direction switching, Power ON/OFF, Data output, inch/mm conversion
    (on inch/metric models only)
    Alarm: Low voltage, Counting value composition error, Over-flow error
    905338: SPC cable (40” / 1m)
    905409: SPC cable (80” / 2m)
    540774: Spindle lifting cable (stroke: .4” / 10mm)
Order NoImageModelRange Resolution Accuracy Measuring Force Stem Diameter Remarks
575-122575-122.jpgID-U1025M0-1in 0-25.4mm.0005in 0.01mm.0008in1.8N or less5/16inM2.5x0.45 Thread ISO/JIS type
575-123575-123.jpgID-U1025E0-1in 0-25.4mm.0005in 0.01mm.0008in1.8N or less3/8inNo.4-48 UNF Thread ANSI/AGD type
