ABSOLUTE Digimatic Indicators ID-F Series-with Back-Lit LCD Screen
Series 543
  • With the ABSOLUTE Linear Encoder technology, once the measurement reference point has been preset it will not be lost when the power is turned on.
  • GO/±NG judgment is performed by setting the upper and lower tolerances. If a judgment result is out of tolerance, the display backlighting changes from green to red, so tolerance judgment can be made at a glance.
  • An analog bar indicator has been integrated to handle upper/lower limit approaching and zero approaching. It enhances the ease of operation in the same manner as a dial indicator. The display range of the analog bar can be changed.
  • With SPC data output.
    Resolution: 0.01mm/0.001mm or .00005”/.0001”/.0005”/.001”/0.001mm/0.01mm
    Measuring force: 1.8N/2.3N* or less (*50mm range models)
    Power supply: 9V DC (via AC adaptor)
    Origin-set/Preset, Zeroset, GO/±NG judgment, Max/Min value
    hold, Runout measurement, Resolution switching, Counting
    direction switching, Power ON/OFF, Data output,
    inch/mm conversion (on inch/metric models only)
    Alarm: Low voltage, Counting value composition error,
    Over-flow error, Tolerance limit setting error
    Standard Accessories
    06AEG302JA: AC Adapter 120v
    137693: Lifting Lever
    936937: SPC cable (40” / 1m)
    965014: SPC cable (80” / 2m)
    540774: Spindle lifting cable (stroke: .4” / 10mm)
    02ACA571: Auxiliary spindle spring for 25mm/1” models*
    02ACA773: Auxiliary spindle spring for 50mm/2” models*
    264-504-5A: Digimatic Min-processor DP-1VR
    543-004-1: Digimatic presetter
Order NumberImageMeasuring Range LCD Resolution Accuracy(20ºC)
543-552A543-552A.jpg0-1in 0-25mm.00005/.0005/.0001/.001in 0.001/0.01mm±.00012in .003mm
543-558A543-558A.jpg0-2in 0-50.8mm.00005/.0005/.0001/.001in 0.001/0.01mm±.00012in .003mm
line drawings product manuals
