ABSOLUTE Digimatic Micrometers Series 227-with Adjustable Measuring Force
Series 227
  • Constant and low measuring force mechanism in the thimble.
  • Adjustable measuring force* accommodates various kind of work materials. *0.5-2.5N or 2-10N
  • The measurement-value hold function automatically retains the data at a specified measuring force, ensuring accuracy.
  • Non-rotating spindle and the new ratchet friction thimble.
  • Speedy spindle feed of 10mm/rev. and .4”/rev for inch/metric model.
  • With absolute linear scale.
  • With SPC data output.
  • With a standard bar to set the origin point (for models with 15 - 30mm / .6” - 1.2” range).
Parallelism: 2µm/.00008”
Battery life: Approx. 3 years under normal use
(1 year for 15-30mm / .6 - 1.2” range model)
Origin-set, Power ON/OFF, Data hold, Data output, Preset
(15-30mm / .6 - 1.2” range model), inch/mm conversion
(inch/mm models)
937387: SPC cable (1m / 40”)
965013: SPC cable (2m / 80”)
Order numberImageRangeResolutionAccuracy Measuring ForceMass
227-211227-111.JPG0- .6in 0-15mm.00005in-0.001mm.0001in-0.002mm0.5-2.5N300g
227-213-.6- 1.2in 15-30mm.00005in-0.001mm.0001in-0.002mm0.5-2.5N380g
227-215-0- .4in 0-10mm.00005in-0.001mm.0001in-0.002mm2-10N340g
227-216-.4- .8in 10-20mm.00005in-0.001mm.0001in-0.002mm2-10N425g
227-217-.8- 1.2in 20-30mm.00005in-0.001mm.0001in-0.002mm2-10N415g
