ABSOLUTE Digimatic Scale Units Series 572
Series 572
  • The ORIGIN key allows setting of an absolute zero point to be used as reference in subsequent measurements. Once set, the ABS Digimatic Scale Unit is ready to show its true position whenever turned on rather than 0.00” as with standard models.
  • The ZERO/ABS key allows the display to be zero-set at any slider position along the beam for incremental comparison measurements. This key will also allow return to the absolute coordinate with a display of the true position from the origin point.
  • No rack, no pinion, no glass scale. Digimatic Scale Unit is safely embedded in the hardened stainless steel blade.
  • Horizontal or vertical face according to the scale mounting direction.
  • Special type that is provided with diameter displaying function is available for lathes.
  • All units come with two mounting brackets, each located at either end of the scale.
  • With SPC data output.
Length standard: ABSOLUTE electrostatic capacitance type
linear encoder
Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting, Power on/off, Presetting, Data hold,
Data output, inch/mm conversion (on inch/metric models only),
Counting direction switching*
*not available for single function models
959143: Data hold unit for single function type
959149: SPC cable with data switch for single function type (40” / 1m)
959150: SPC cable with data switch for single function type (80” / 2m)
905338: SPC cable (40” / 1m standard)
905409: SPC cable (80” / 2m standard)
905689: SPC cable (40” / 1m L-shape, back)
905690: SPC cable (80” / 2m L-shape, back)
905691: SPC cable (40” / 1m L-shape, right)
905692: SPC cable (80” / 2m L-shape, right)
905693: SPC cable (40” / 1m L-shape, left)
905694: SPC cable (80” / 2m L-shape, left)
TypeOrder NoModelRange Accuracy Resolution
Horizontal single-function572-210-20SD-4"DX0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Horizontal single-function572-211-20SD-6"DX0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Horizontal single-function572-212-20SD-8"DX0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Horizontal single-function572-213-10SD-12"D0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Vertical single function572-310-10SD-6"D0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Vertical single-function572-311-10SD-6"D0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Vertical single function572-312-10SD-8"D0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Vertical single function572-313-10SD-12"D0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function572-470SD-4"E0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function572-471SD-6"E0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function572-472SD-8"E0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function572-473SD-12"E0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function572-474SD-18"E0-18in 0-450mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function572-475SD-24"E0-24in 0-600mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function572-476SD-32"E0-32in 0-800mm.0025in0.06mm.0005in 0.01mm
Horizontal multi-function572-477SD-40"E0-40in 0-1000mm.0025in0.06mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-490-10SD-4"F0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-491-10SD-6"F0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-492-10SD-8"F0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-493-10SD-12"F0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-494-10SD-18"F0-18in 0-450mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-495-10SD-24"F0-24in 0-600mm.002in0.04mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-496-10SD-40"F0-32in 0-800mm.0025in0.06mm.0005in 0.01mm
Horizontal multi-function (equipped with double reading function)572-497-10SD-40"F0-40in 0-1000mm.0025in0.06mm.0005in 0.01mm
Vertical multi-function572-570SDV-4"E 0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Vertical multi-function572-571SDV-6"E0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Vertical multi-function572-572SDV-8"E0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Vertical multi-function572-573SDV-12"E0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Vertical multi-function572-574SDV-18"E0-18in 0-450mm.002in0.04mm.0005in 0.01mm
Vertical multi-function572-575SDV-24"E0-24in 0-600mm.002in0.04mm.0005in 0.01mm
Vertical multi-function572-576SDV-32"E0-32in 0-800mm.0025in0.06mm.0005in 0.01mm
Vertical multi-function572-577SDV-40"E0-40in 0-1000mm.0025in0.06mm.0005in 0.01mm
Vertical multi-function type (equipped with double reading)572-590-10SDV-4"F0-4in 0-100mm.001in0.03mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-591-10SDV-6"F0-6in 0-150mm.001in0.03mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-592-10SDV-8"F0-8in 0-200mm.001in0.03mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-593-10SDV-12"F0-12in 0-300mm.002in0.04mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-594-10SDV-18"F0-18in 0-450mm.002in0.04mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-595-10SDV-24"F0-24in 0-600mm.002in0.04mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-596-10SDV-32"F0-32in 0-800mm.0025in0.06mm.0005in 0.01mm
Vertical multi-function (equipped with double reading function)572-597-10SDV-40"F0-40in 0-1000mm.0025in0.06mm.0005in 0.01mm
