ABSOLUTE Digimatic & Vernier Caliper Series 550,160-with Nib Style Jaws
Series 550
  • The rounded faces of the jaws are ideal for accurate ID (inside diameter) measurement.
  • Inside and outside measurements can be directly read from the upper and lower slider graduations (Series 160).
  • With fine-adjustment carriage type is available (Series 160).
  • Parallax-free vernier scale type is available for easy and positive measurement (Series 160).
  • With SPC output (Series 550).
  • Supplied in fitted plastic case. Except 1000mm / 40” supplied in wooden case.
Accuracy: Refer to the list of specifications
Display*: LCD
Length standard*: ABSOLUTE electrostatic capacitance type linear encoder
Max. response speed*: Unlimited
Battery life*: Approx. 3.5 years under normal use
Function of Digital Model
Origin-set, Zero-setting, Data output,
inch/mm conversion (on inch/metric models only)
959143: Data hold unit
959149: SPC cable with data switch (40” / 1m)
959150: SPC cable with data switch (80” / 2m)
05CZA624: SPC cable with data switch (40” / 1m) for IP67 model
05CZA625: SPC cable with data switch (80” / 2m) for IP67 model
Order NumberImage Range LCD Resolution AccuracyRemarksMass
550-311-10550-311-10.jpg0(.4)-8in 0(10)-200mm.0005in 0.01mm.001inIP67180g
550-341-10550-341-10.jpg0(.4)-12in 0(10)-300mm.0005in 0.01mm.0015inIP67380g
550-223-10550-223-10.jpg0(.5)-18in 0(20)-450mm.0005in 0.01mm.002in-1,110g
550-225-10550-225-10.jpg0(.5)-24in 0(20)-600mm.0005in 0.01mm.002in-1,290g
550-227-10550-227-10.jpg0(1)-40in 0(20)-1000mm.0005in 0.01mm.003in-3,350g
