ABSOLUTE Low Force Caliper Series 573
Series 573
  • Due to the low measuring force these calipers are ideal for elastic or resilient workpieces such as plastic parts and rubber parts that standard calipers cannot measure.
  • With SPC data output.
Measuring force: 0.49N to 0.98N (50gf to 100gf)
Jaw retraction: 0.3mm
Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
959143: Data hold unit
959149: SPC cable with data switch (40” / 1m)
959150: SPC cable with data switch (80” / 2m)
Order NumberImageRangeLCD Resolution Accuracy Mass (g)
573-291-30573-291-20.jpg0-7in 0-180mm.0005in 0.01mm.002in253
