ABSOLUTE Snap Caliper Series 573
Series 573
  • The ABSOLUTE Digimatic snap caliper features a spring-loaded mechanism to allow quick and efficient GO/NO-GO inspection for mass production parts..
  • With SPC data output.
Accuracy: Refer to the list of specifications. (excluding quantizing error for digital models)
Repeatability: .0005” / 0.01mm
Measuring force: 7N to 14N (700gf to 1400gf)
Jaw retraction: 2mm
Battery: SR44 (1 pc.), 938882 Battery life: Approx. 3.5 years under normal use
Origin-set, Zero-setting, Power On/Off, Data output, inch/mm conversion (inch/mm models)
959143: Data hold unit
959149: SPC cable with data switch (40” / 1m)
959150: SPC cable with data switch (80” / 2m)
Order NumberImageRangeLCD Resolution Accuracy Mass (g)
573-281-30573-281-20.jpg0-4in 0-100mm.0005in 0.01mm.001213
573-282-30-0-6in 0-150mm.0005in 0.01mm.001233
