ABSOLUTE Super Caliper SERIES 500-No battery or origin reset needed
Series 500
Mitutoyo's Absolute Solar Digimatic Caliper
retains its origin point even if the display turns
off for the entire life of the caliper. At 60
Lux and up the ABSOLUTE solar caliper is, turned on ready to start measurement.
  • No more repeated zero setting caused by the shortage of light intensity.
  • Hard-coated solar panel for safe operation.
  • No fear for overspeed errors.
  • With thumb roller.
Repeatability: 0.01mm / .0005”
Length standard:ABSOLUTE electrostatic capacitance type
linear encoder
Battery: Solar battery*
*Can be used continuously above 60 lux ambient illumination.
Origin-set, Data hold, Data output, inch/mm conversion
(inch/ mm models)
Alarm: Counting value composition error
959143: Data hold unit (SPC output model only)
959149: SPC cable with data switch (1m / 40”)
959150: SPC cable with data switch (2m / 80”)
Order NoImageRange LCD ResAccuracyRemarks
500-463500-463.jpg0-4in 0-100mm.0005in 0.01mm±.001in .075in Round Depth Bar with SPC output
500-473500-473.jpg0-4in 0-100mm.0005in 0.01mm±.001in .075" Round Depth Bar without SPC output
500-464500-464.jpg0-6in 0-150mm.0005in 0.01mm±.001in with SPC output
500-474500-474.jpg0-6in 0-150mm.0005in 0.01mm±.001in without SPC output
500-465500-465.jpg0-8in 0-200mm.0005in 0.01mm±.001in with SPC output
500-475500-475.jpg0-8in 0-200mm.0005in 0.01mm±.001in without SPC output
