ABSOULTE Digimatic Depth Gage Series 571
Series 571
  • ABSOLUTE Digimatic Depth Gage can keep track of the origin point once set for the entire life of the battery.
  • Base and measuring faces are hardened and micro-lapped.
  • Optional wider extension base are available. (up to 450mm range models)
  • With SPC data output.
Repeatability: 0.01mm
Length standard: ABSOLUTE electrostatic capacitance
(electromagnetic induction)* type linear encoder
Battery life: Approx. 20,000 hours (3 years)* under normal use
Dust/Water protection level: IP67*
*Coolant Proof models
Origin-set, Zero-setting, Automatic power on/off, Data output, inch/mm conversion (inch/mm models)
959143: Data hold unit
959149: SPC cable with data switch (40” / 1m)
959150: SPC cable with data switch (80” / 2m)
05CZA624: SPC cable with data switch (40” / 1m)*
05CZA625: SPC cable with data switch (80” / 2m)*
*for IP67 models
Order No.ImageRange Resolution AccuracyMass
571-216-10571-216-10.jpg0-30in 0-750mm.0005in 0.01mm.0025in1530g
571-217-10-0-40in 0-1000mm.0005in 0.01mm.0025in1760g
571-261-20*571-261-10.jpg0-6in 0-150mm.0005in 0.01mm.001in199g
571-262-20*571-262-10.jpg0-8in 0-200mm.0005in 0.01mm.001in219g
571-263-10*571-263-10.jpg0-12in 0-300mm.0005in 0.01mm.0015in1270g
571-211-30571-211-20.jpg0-6in 0-150mm.0005in 0.01mm.001in192g
571-212-30-0-8in 0-200mm.0005in 0.01mm.001in212g
571-213-10571-213-10.jpg0-12in 0-300mm.0005in 0.01mm.0015in310g
571-214-10-0-18in 0-450mm.0005in 0.01mm.002in1270g
571-215-10-0-24in 0-600mm.0005in 0.01mm.002in1400g
