Accessories for Measuring Microscopes
Series 176
  • By installing this system on the camera mount of an MF series measuring microscope and projecting the focusing chart onto the work piece surface, the focal point can be detected with high-accuracy and high-repeatability.
  • The brightness of the chart can be adjusted.
  • A wide view field observation on the monitor is made possible with the use of a CCD camera (C-mount adapter is included.)
  • Four types of chart patterns are available. The pattern should be selected in accordance with the type of work piece surface texture.
Order No.Description---------------------------------------------------------------------
176-343A
Twin Fiber Optics Illuminator
Applicable microscopes
MF, MF-U models
Length of fiber cable
28" / 700mm
Light source
Halogen bulb (12V, 100W) (
517181 : halogen bulb)
Dimensions (W x D x H)
Light unit: 9.3 x 3 x 4.7"
235 x 76 x 120mm
176-366A
Ring Fiber Optics Illuminator
MF models
40" x 1000mm
Light source
235 x 76 x 120mm
176-367-2A
LED Ring Optics Illuminator (White)
MF models with 1X/3X/5X/10X objective
Light source
White LED
Length of LED cable
59" / 1500mm
375-056
Micro-Scale For MF
Range
1mm
Graduations
0.01mm
Accuracy (at 20°C)
(1+L)μm, L = Measuring length (mm)
Dimensions (WxD)
3" x 1" / 76 x 26mm
Mass
16g
375-057A
FOCUS PILOT FP-05 (GREEN LED)
Order No.
375- 057A
375-058A
375-067A
375-068A
MF D models
MF-U D models
Light source
Green LED
Red LED
Green LED
Red LED
Magnification
0.5X, Accuracy: 0.1%**
Camera adapter
C-mount (provided)
Applicable CCD camera
Up to 2/3-inch
Mass
4lbs / 1.8kg
375-058A
FOCUS PILOT FP-05 (RED LED)
Order No.
375-057A
375-058A
375-067A
375-068A
MF D models
MF-U D models
Light source
Green LED
Red LED
Green LED
Red LED
Magnification
Camera adapter
C-mount (provided)
Up to 2/3-inch
Mass
4lbs / 1.8kg
375-067A
FOCUS PILOT FP-05U (GREEN LED)
Order No.
375-057A
375-058A
375-067A
375-068A
MF D models
MF-U D models
Light source
Green LED
Red LED
Green LED
Red LED
Magnification
Camera adapter
C-mount (provided)
Up to 2/3-inch
Mass
4lbs / 1.8kg
375-068A
FOCUS PILOT FP-05U (RED LED)
Order No.
375-057A
375-058A
375-067A
375-068A
MF D models
MF-U D models
Light source
Green LED
Red LED
Green LED
Red LED
Magnification
Camera adapter
C-mount (provided)
Up to 2/3-inch
Mass
4lbs / 1.8kg
176-211
Manual and Power Turrets
Order No.
176-211
378-018
176-210A
378-016A
378-116A
Observation type
BD
BF
BD
BF
BF
No. of objective mounts
4-mount
4-mount
4-mount
4-mount
5-mount
Driving method
Manual
Motor
Turret: 6.5 x 2.6 x 5.4"
164 x 65 x 137
Control Box: 4.1 x 3 x 7.6"
108 x 72 x 193
