Bench Center Series 967
Series 967
  • Used with a dial test indicator (optional), the Bench Center provides
    precision measurement of concentricity verification on cylindrical workpieces.
  • With an indicator clamp. (Holding stem diameter: 9.53mm / .375”)
Maximum workpiece dia.: 300mm
Maximum workpiece height: 150mm
Mass: 13kg
Spindle Tip Material: Hardened Steel
Standard Accessories:
56AAK066 Indicator rod assembly
967-201-10
967-203-10
56AAK961R Indicator rod assembly
967-202-10
967-204-10
Optional Accessories:
56AAJ988 Special attachment for mounting 967-201-10 in vertical position.
56AAJ987 Special attachment for mounting 967-203-10 in vertical position.
Order NumberCenter to CenterWorkpiece Capacity DiameterMax. WeightParallelism of CentersFlatness of SurfaceAttachment Diameter
967-201-1011.8in5.8in35lbs.0002in.0006in3/8in
967-202-1023.6in9.8in66lbs.00024in.0008in3/8in
967-203-105.9in3.8in17.5lbs.0002in.0004in3/8in
967-204-1017.7in7.8in44lbs.0002in.0007in3/8in
