Blade Micrometers - Series 422, 122 - Non-Rotating Spindle
Series 422
  • The anvil and the spindle have a blade for measuring
    the groove diameter of shafts, keyways, and other hard-to-reach areas.
  • Speedy spindle feed of 10mm / .4”/rev. (Quickmike type).
  • With a standard bar except 0 -25mm and 0 - 1” model.
Resolution*: 0.001mm or .00005"/0.001mm
Graduation**: 0.01mm or .0001"
Parallelism: 3ìm / .00012” for models up to 75mm / 3”
(3+R/100)ìm for models over 75mm,
R=max. range (mm) .00016” for 4” models
Display*: LCD
Function of Digital Model
Origin-set, Zero-setting, Data hold, Data output, inch/mm
conversion (inch/mm models)
05CZA662: SPC cable with data switch (1m / 40”)
05CZA663: SPC cable with data switch (2m / 80”)
937387: SPC cable for Quickmike type (1m / 40”)
965013: SPC cable for Quickmike type (2m / 80”)
InchInch/MetricMetric
Order NoImageRange AccurTypeMass
122-125122-125.jpg0-1in±.00015inA260g
122-126122-126.jpg1-2in±.00015inA300g
122-127122-127.jpg2-3in±.00015inA360g
122-128122-128.jpg3-4in±.0002inA525g
122-135-0-1in±.00015inB260g
122-151122-151.jpg0-1in±.00015inD275g
line drawings videos
