Bore Gages Series 511-with Micrometer Head
Series 511
  • Interchangeable anvil is attached to a micrometer head for accurate dimensional setting.
  • Wide measuring range with sub-anvils.
  • Carbide ball contact point for durability.
  • Extension rods (optional) can be attached for measuring deep holes.
  • Optional Setting Rings offer the best method of zero-setting Bore Gages.
Accuracy:2µm/.0008”
Indication stability:1µm/.00004”
Graduation: 0.01mm, 0.001mm, .0005” or .0001"
953552:125mm/4.92” Extension rod for 35-160mm/1.4- 6.5" models
953557:125mm/4.92” Extension rod for 160-400mm/6.5-16" models
953553:250mm/9.84” Extension rod for 35-160mm/1.4-6.5" models
952361:250mm/9.84” Extension rod for 160-400mm/6.5-16" models
953554:500mm/19.69” Extension rod for 35-160mm/1.4-6.5" models
953558:500mm/19.69” Extension rod for 160-400mm/6.5-16" models
953555:750mm/29.53" Extension rod for 35-160mm/1.4-6.5" models
953559:750mm/29.53” Extension rod for 160-400mm/6.5-16" models
953556:1000mm/39.37” Extension rod for 35-160mm/1.4-6.5" models
953560:1000mm/39.37” Extension rod for 160-400mm/6.5-16" models
*Does not come with Dial Gage Protector Cover (21DZA000)
InchMetric
RangeOrder NoHead Travel Sub AnvilRemarks
2.4-4in511-833*.4in.4in,.8inWithout Indicator
4-6.4in511-834*.5in.4in,.8in,.8inWithout Indicator
6-10in511-835*.5in.4in,.8in,.8in,2inWithout Indicator
10-16in511-836*1in1in,2in,2inWithout Indicator
16-24in511-837*2in2in,4inWithout Indicator
24-32in511-838*2in2in,4inWithout Indicator
2.4-4in511-843.4in.4in,.8inWith 2922SB
Grad .0005in
4-6.4in511-844.5in.4in,.8in,.8inWith 2922SB
Grad .0005in
6-10in511-845.5in.4in,.8in,.8in,2inWith 2922SB
Grad .0005in
10-16in511-8461in1in,2in,2inWith 2922SB
Grad .0005in
16-24in511-8472in2in,4inWith 2922SB
Grad .0005in
24-32in511-8482in2in,4inWith 2922SB
Grad .0005in
2.4-4in511-853.4in.4in,.8inWith 2923SB-10
Grad .0001in
4-6.4in511-854.5in.4in,.8in,.8inWith 2923SB-10
Grad .0001in
6-10in511-855.5in.4in,.8in,.8in,2inWith 2923SB-10
Grad .0001in
10-16in511-8561in1in,2in,2inWith 2923SB-10
Grad .0001in
16-24in511-8572in2in,4inWith 2923SB-10
Grad .0001in
24-32in511-8582in2in,4inWith 2923SB-10
Grad .0001in
