Borematic 568-ABSOLUTE Digimatic Snap-Open Bore Gages
Series 568
The Borematic enables the operator to take measurements more accurately and more quickly than ever before. Once the origin point is set with the ORIGIN button, the Borematic retains the setting for the entire battery life. Therefore no longer repeated origin setting (presetting) is necessary.
  • TiN-coated measuring contact points provide excellent durability and impact resistance and allow the instrument to measure right to the bottom of a blind hole.
  • Large LCD digits of 8.5mm height for error-free reading.
  • 330-degree rotatable display unit for easy reading at any angle.
  • GO/NO-GO judgment function.
  • The ABSOLUTE linear encoder eliminates the fear of over-speed errors.
  • With SPC data output.
  • Setting rings for origin point setting are optional.
  • Can measure deep holes by attaching an optional extension rod.
  • Measurement can be taken closer to the bottom of a blind bore.
  • Supplied in fitted wooden case.
Accuracy: Refer to the list of specifications
Contact point: Carbide or titanium coating* (*over 12mm/.5" models)
Measuring method: Three-point method
Battery: SR44 (1 pc.) (938882)
Battery life: Approx. 7,000 hours
Functions
Zero-Set, presetting, GO/NO-GO judgment, power on/off,
inch/mm conversion (inch/mm type only), SPC data output, data hold
905338: SPC cable (1m / 40”)
905409: SPC cable (2m / 80”)
952322: Extension rod 100mm / 3.94” For range 6-12mm / .275-.5” models
952621: Extension rod 150mm / 5.9” For range 12-20mm / .5" - .8” models
952622: Extension rod 150mm / 5.9” For range 20-50mm / .8" - 2” models
952623: Extension rod 150mm / 5.9” For range 50-300mm / 2"-12” models
Inch/MetricInch/Metric/SetMetricMetric/Set
Order NoModelRange Head Assy Order No.AccuracyMass
568-461SBM-.35”C.275-.350in
6.985-8.89mm
04AZB139.00025in480g
568-462SBM-.425”C.350-.425in
8.89-10.795mm
04AZB140.00025in485g
568-463SBM-5”C.425-.5in
10.795-12.7mm
04AZB141.00025in485g
568-464SBM-.65”C.50-.65in
12.7-16.51mm
04AZA721.00025in475g
568-465SBM-.8”C.65-.80in
16.51-20.32mm
04AZA722.00025in480g
568-466SBM-1”C.8-1.0in
20.32-25.4mm
04AZA730.0003in540g
568-467SBM-1.2”C1.0-1.2in
25.4-30.48mm
04AZA731.0003in555g
568-468SBM-1.6”C1.2-1.6in
30.48-40.64mm
04AZA739.0003in565g
568-469SBM-2”C1.6-2.0in
40.64-50.8mm
04AZA740.0003in610g
568-470SBM-2.5”C2.0-2.5in
50.8-63.5mm
04AZA754.0003in730g
568-471SBM-3”C2.5-3.0in
63.5-76.2mm
04AZA755.0003in740g
568-472SBM-3.5”C3.0-3.5in
76.2-88.9mm
04AZA756.0003in790g
568-473SBM-4”C3.5-4.0in
88.9-101.6mm
04AZA757.0003in800g
568-474SBM-4.5”C4.0-4.5in
101.6-114.3mm
04AZA943.0003in900g
568-475SBM-5”C4.5-5.0in
114.3-127mm
04AZA944.0003in910g
