CERA Caliper Checker-SERIES 515
Series 515
  • The CERA Caliper Checker is designed to inspect vernier, dial and Digimatic calipers. It is comprised of permanently wrung, high-grade CERA gage blocks in a protective casting.
  • The CERA Caliper Checker also standsperpendicular to a surface for height gage inspection.
  • The zirconia-based ceramic CERA measuring blocks are corrosion-resistant and dimensionally stable.
Block pitch accuracy:
±0.005mm for range up to 300mm
±.0002” for range up to 12 “
±0.007mm for range up to 600mm
Parallelism of blocks:
0.002mm for range up to 300mm
0.004mm for range up to 600mm
Optional Accessories:
602162: Wooden case for 300mm model
602164: Wooden case for 600mm model
InchMetric
Order NumberImageRangeBlock Pitch Accuracy Parallelism Weight
515-565515-565.JPG0-12in.0002in80uin17.6lbs
product manuals
