CERA Caliper Checker Series 515
Series 515
  • The CERA Caliper Checker is designed to inspect vernier, dial and Digimatic calipers. It is comprised of permanently wrung, high-grade CERA gage blocks in a protective casting.
  • The CERA Caliper Checker also stands perpendicular to a surface for height gage inspection.
  • The zirconia based ceramic CERA measuring blocks are corrosion resistant and dimensionally stable.
Block pitch accuracy: ±0.005mm for range up to 300mm±.0002”
For range up to 12 “±0.007mm for range up to 600mm
Parallelism of blocks: 0.002mm for range up to
300mm0.004mm for range up to 600mm
602162: Wooden case for 300mm model
602164: Wooden case for 600mm model
InchMetric
Order NoImageRangeMassLength to check
515-565515-565.JPG0-12in4kgOutside measurement: 1”, 2”, 4”, 6”, 8”, 10”, 12”
Inside measurement: 1”, 2”, 4”, 6”, 8”, 10”, 12”
line drawings product manuals
