CRYSTA-Apex EX 1200R Series 191-Revo Equipped 5-Axis CNC CMM
Series 191
The CRYSTA-Apex EX 1200R series products are advanced CNC CMMs equipped with the REVO 5-axis scanning probe head. The 5-axis operation reduces the time required for probe repositioning movements and allows for more flexible positioning. This also facilitates access to complex workpieces and saves time both during programming and measurement. The ultra-high-speed 5-axis scanning (max. 500mm/ s), surpasses conventional 3-axis control supporting high speed sampling of up to 4,000 points per second allowing data acquisition of densely spaced measurement points, even during high speed scanning. The internal implementation of laser sensing technology ensures high accuracy measurement, even with long styli (up to 500 mm as measured from probe rotation center to stylus tip). Two types of scanning probes are supported:
  • RSP2 for 5-axis scanning
  • RSP3 probe (SP25M type), allowing the use of a cranked stylus Automatic changeover of these probes with an auto probe changer is possible, enabling fully automated measurement of parts with diverse shapes. Probe calibration of RSP2 requires only about 20 minutes to enable use of the full angular range. Compared to conventional scanning probes, which notably reduces preparation time.
  • Equipped with REVO 5-axis scanning probe head
  • Ultra-high speed 5-axis scanning
    Model CRYSTA-Apex EX 121210RCRYSTA-Apex EX 122010RCRYSTA-Apex EX 123010R
    Order No.191-392V191-394V191-396V
    TypeBRIDGE TYPEBRIDGE TYPEBRIDGE TYPE
    RangeX-axis 47.24in1200mm
    Y-axis 47.24in1200mm
    Z-axis 39.36in1000mm
    Y-axis 78.73in2000mm
    Y-axis 118.10in3000mm
    Resolution 0.000004in (0.0001mm)0.000004in (0.0001mm)0.000004in (0.0001mm)
    Guide MethodAir bearing on each axisAir bearing on each axisAir bearing on each axis
    Work tableMaterial-Granite
    Size
    55.92x85.23in
    1420x2165mm
    Tapped insert-M8x1.25mm
    Material-Granite
    Size
    55.90x116.73in
    1420x2965mm
    Material-Granite
    Size
    55.90x156.10in
    1420x3965mm
    Work pieceMax. height-45.66in 1160mm
    Max load-4,409lbs2000kg
    Max load-5,511lbs2500kg
    Max load-6,613lbs3000kg
    Mass (incl.stand & controller)8,928lbs 4050kg13,558lbs 6150kg20,084lbs 9110kg
    Dimension WxDxH86.61x100.19x143.50 2200x2545x3645 86.61x131.69x143.50 2200x3345x3645 86.61x171.06x143.50 2200x4345x3645
    ISOISO-10360-2:2009
    E0,MPE
    18-22°C (64.4-71.6°F) (2.9+4L/1000)µm
    16-26°C (60.8-78.8°F) (2.9+5L/1000)µm
    ISO-10360-5: 2010 PFTU,MPE 3.2µm
    ISO-10360-2:2009
    E0,MPE
    ISO-10360-2:2009
    E0,MPE
