CRYSTA-Apex EX 500T/700T/900T PH20 Equipped 5-Axis CNC CMM
Series 191
The CRYSTA-Apex EX 500T/700T/900T series are CNC CMMs equipped with the PH20 5-axis control touchtrigger probe. The 5-axis operation reduces the time required for probe rotational movements and allows more flexible positioning. This also ensures easy access to complex workpieces and saves time both during programming and measurement. In addition to 3-axis point measurement similar to conventional coordinate measuring machines, the PH20 probe head also supports ‘head touch’ operation for quick point measurement using the two rotational axes of the probe only, with no movement required along the CMM axes. The PH20 incorporates a TP20 probe and allows use of modules designed for the TP20. Automatic probe changes with a module changer is also supported with the use of the TCR20 change rack (OPTION).
  • Incorporates PH20 5-axis touch-trigger probe
  • Ultra-high speed 5-axis control touch-trigger probe
  • Smooth 5-axis control drastically reduces measurement time (typically 40-65%) for probe rotation
  • 5-axis design provides highly efficient measurement method of “head touch” for point measurement by moving the probe head only in two axes
    † This test is not part of Mitutoyo America’s standard A2LA accredited CMM calibration proceedure and is quoted upon request.
ModelCRYSTA-Apex EX 544TCRYSTA-Apex EX 574TCRYSTA-Apex EX 776T
Order No.191-244-20191-248-20191-252-20
TypeBRIDGE TYPEBRIDGE TYPEBRIDGE TYPE
RangeX-axis 19.68in500mm
Y-axis 15.74in400mm
Z-axis 15.74in400mm
X-axis 19.68in500mm
Y-axis 27.55in700mm
Z-axis 15.74in400mm
X-axis 27.55in700mm
Y-axis 27.55in700mm
Z-axis 23.62in600mm
Resolution0.000004"(0.0001mm)0.000004"(0.0001mm)0.000004"(0.0001mm)
Guide MethodAir bearing on each axisAir bearing on each axisAir bearing on each axis
Work tableMaterial-Granite
Size25.11x33.86in
638x860mm
Tapped insert-M8x1.25mm
Material-Granite
Size25.11x45.67in
638x1160mm
Material-Granite
Size34.64x55.90in
880x1420mm
Work pieceMax. height-21.45in 545mm
Max load-396lbs180kg
Max. height-31.49in 800mm
Max load-1763lbs800kg
Mass (incl. stand & controller1,181lbs 536kg646lbs 1,424kg3,739lbs 1696kg
ISOISO-10360-2:2009 E0,MPE
18-22°C (64.4-71.6°F)-(2.2+3L/1000)μm
16-26°C (60.8-78.8°F)- (2.2+4L/1000)μm
ISO-10360-2:2009†
R0,MPL -1.8μm
ISO-10360-5: 2010
PFTU,MPE 2.2μm
ISO-10360-2:2009†
R0,MPL -1.8μm
ISO-10360-5: 2010
PFTU,MPE 2.2μm
ISO-10360-2:2009†
R0,MPL -1.8μm
ISO-10360-5: 2010
PFTU,MPE 2.2μm
Dimension WxDxH42.60x44.17x86.02in
1082x1122x2185mm
42.60x57.40x86.02in
1082x1458x2185mm
57.87x64.96x107.48in
1470x1650x2730mm
Pages: 1    2    3
videos literature
