CRYSTA-Plus M Series 196-Manual-Floating Type CMM
Series 196
Manual floating type CMMs developed in quest for high-accuracy, low-cost and easy operation. The Crysta-Plus M is suitable to
measure a wide range of applications from a simple dimension to complex form. The scale systems on Mitutoyo high-precision models utilizes a high-performance linear encoder (manufactured by Mitutoyo), for detecting axis position. In addition, various
technologies have been utilized in the structure, part processing, and assembly to provide high accuracy measurement.
The Crysta-Plus M700 series has a large main unit, and is equipped with a mobile clamp so that onetouch clamping on each axis can be performed by hand. Continuous fine feed over the entire measuring range can be performed.
  • Smooth operation utilizing high-precision air bearings and lightweight moving members.
  • Continuous fine feed over the entire measuring range.
  • One-touch air clamp for each axis.
PARTS
Order No.196-683196-495-55196-352
ModelCrysta-Plus M443Crysta-Plus M574Crysta-Plus M7106
TypeBridge Type -
Standard, Manual
Bridge Type -
Standard, Manual
Bridge Type -
Standard, Manual
X-axis Range 15.74in 400mm19.69in 500mm27.56in 700mm
Y-axis Range 15.74in 400mm27.56in 700mm39.37in 1000mm
Z-axis Range 11.81in 300mm15.74in 400mm23.62in 600mm
Resolution0.000019in 0.0005mm0.000019in 0.0005mm.00002in 0.0005mm
Work table MaterialGraniteGraniteGranite
Work table Size24.56x31.69in 624x805mm30.07x46.25in 764x1175mm34.43x68.50in 900x1740mm
Tapped insertM8x1.25mmM8x1.25mmM8x1.25mm
Workpiece Height18.89in 480mm23.22in 590mm31.49in 800mm
Workpiece load396lbs 180kg396lbs 180kg1763lbs 800kg
Mass (stand included)793lbs 360kg1424lbs 646kg3968lbs 1800kg
Dimension38.62x41.22x77.44in 981x1047x1967mm56.45x47.44x89.25in 1434x1205x2267mm57.48x79.40x111.42in 1460x2017x2840mm
Air SupplyPressure 50.7 PSI (0.35MPa)
Consumption 1.76CFM (50L/min)
Source 3.53CFM (100L/min)
Pressure 58.0 PSI (0.4MPa)
literature
