Contracer CV-3200 / 4500 Series 218-Contour Measuring Instruments
Series 218
  • Dramatically increased drive speed (X axis: 80 mm/s, Z2 axis: 20 mm/s) further reduces total measurement time.
  • In order to maintain the traverse linearity specification for an extended period of time, Mitutoyo has adopted highly rigid ceramic guides that combine the characteristics of smallest secular change and remarkable resistance to abrasion.
  • With the support for a wide range of optional peripherals designed for use with the CNC models enables simplified CNC measurement.
  • The drive unit (X-axis) and column (Z2- axis) are equipped with a high-accuracy linear encoders (ABS type on Z2-axis). This improves reproducibility of continuous automatic measurement of small holes in the vertical direction and repeated measurement of parts which are difficult to position.
  • X axis accuracy: ±(0.8+0.01L)ìm Z1 axis accuracy: ±(0.8+I0.5HI/25)ìm* Designed to handle workpieces calling for high accuracy.
*CV-3200S4, H4, W4 types
L = Drive length, H = Measurement height (mm)
CV3200CV4500
Model No.CV-3200S4CV-3200H4CV-3200W4CV-3200S8
Order No.218-491-10A218-492-10A218-493-10A218-496-10A
X1-axis measuring range4in 100mm4in 100mm4in 100mm8in 200mm
Vertical travel----
Granite base size (WxD)23.6x17.7in 600x450mm23.6x17.7in 600x450mm39.4x17.7in 1000x450mm23.6x17.7in 600x450mm
Dimensions(main unit WxDxH)29.2x17.7x35.6in 741x450x905mm29.2x17.7x43.5in 741x450x1105mm44.0x17.7x43.7in 1118x450x1111mm30.2x17.7x35.6in 767x450x905mm
Mass(main unit)309lbs 140kg331lbs 150kg342lbs 155kg320lbs 145kg
Pages: 1    2
videos literature
