Crysta-Apex C1600/2000 Series 191-Standard CNC CMM
Series 191
Engineered and constructed utilizing Mitutoyo's innovative CNC CMM technology, Crysta-Apex features lightweight materials and a stable structure. The result is a design that provides high travel stability, high accuracy, and affordability. The temperature correction function 60.8°F to 75.2°F (16°C to 26°C) can yield accurate measurements even on the shop floor. In addition to the point-to-point measurement, the MPP-100 and a Laser Probe provide contact/non-contact scanning function.
Length standard
Linear encoder
Guide system
Air bearing
Max. Drive speed (3D)
20.43" (519mm)/second
Max. Acceleration
0.17G
Air pressure
0.4MPa
Air consumption
150L/min
ISO10360 Test Parameters
SP25M Probe, Ø 4mm x L 50mm
Main Unit
Startup System
This machine incorporates a startup system
(relocation detection system), which disables operation when
an unexpected vibration is applied or the machine is
relocated. Be sure to contact your nearest Mitutoyo
prior to relocating this machine after initial installation.
Crysta Apex C1600Crysta Apex C2000
ModelCrysta-Apex C163012Crysta-Apex C163016Crysta-Apex C164012
Order No191-262-2191-262H-2191-272-2
TypeLarge Bridge Type
Standard
Large Bridge Type
Standard
Large Bridge Type
Standard
Image---
X-axis62.9" (1600mm)62.9" (1600mm)62.9" (1600mm)
Y-axis118.1" (3000mm)118.1" (3000mm)157.4" (4000mm)
Z-axis47.2" (1200mm)62.9" (1600mm)47.2" (1200mm)
Resolution0.000004" (0.0001mm)0.000004" (0.0001mm)0.000004" (0.0001mm)
ISO10360-2:2009 (E0,MPE)
64.4-71.6°F (18-22°C)1
60.8-75.2°F (16-24°C)2
(3.3+4.5L/1000)µm1
(3.3+5.5L/1000)µm2
(4.5+5.5L/1000)µm1
(4.5+6.5L/1000)µm2
(3.3+4.5L/1000)µm1
(3.3+5.5L/1000)µm2
ISO 10360-4(MPETHP/MPTTHP)5.0µm / 150 seconds5.0µm / 150 seconds5.0µm / 150 seconds
ISO10360-5:20100 (PFTU,MPE)5.0µm6.0µm5.0µm
MaterialGraniteGraniteGranite
Work Table Size70.86"x165.55"
(1800mmx4205mm)
70.86"x165.55"
(1800mmx4205mm)
70.86"x204.92"
(1800mmx5205mm)
Tapped InsertM8x1.25mmM8x1.25mmM8x1.25mm
Max Workpiece Height55.11" (1400mm)70.86" (1800mm)55.11" (1400mm)
Max Workpiece Weight7716lbs (3500kg)7716lbs (3500kg)9920lbs (4500kg)
Mass (including stand and controller)23368lbs (10600kg)23479lbs (10650kg)32628lbs (14800kg)
Machine Dimensions WxDxH106.29"x181.10"x162.99"
(2700mmx4600mmx4140mm)
106.29"x181.10"x194.49"
(2700mmx4600mmx4940mm)
106.29"x220.47"x164.96"
(2700mmx5600mmx4190mm)
Pages: 1    2
