D-EV Display Unit for EV Counter
  • Display unit for the EV counter.
  • Allows set-up of EV counter without a personal computer or other equipment.
  • Able to display each gage measurement value and GO/NG judgment result, total GO/ NG judgment result for all gages, setting details, and errors.
• External Control (Zero-set, Preset etc.)
• Direction switch
• Error display
• Tolerance judgment output
• Data output
(RS-232C, BCD, Segment)
• Peak measurement
Maximum value, minimum value, runout, and differential
measurement between two gages
Addition, averaging, maximum value, minimum value,
and maximum width
• SPC cable (0.5m): No.02ADD950*1
• SPC cable (1mm): No.936937*1
• SPC cable (2m): No.965014*1
• AC adapter: No.02ADN460
• AC cable (USA): 02ZAA010*2
• Terminal connecting cable: 02ADD930*2
*1: Required when connecting with EV-16P/D/Z.
*2: Required when using AC adapter.
Note: AC adapters may not be needed if using power from EV counter to power the D-EV.
Order No02ADD400
Number of connections1 EV counter per unit
Number of digitsSign plus 6 digits (8 digits internal to EV counter)
LED displayChannel display (also for judgment result display): 3 (3-color LED)
Measurement mode display (current data, maximum value, minimum value, runout): 2
Status display: 1 (2 colors)
Operation switches4
Function of operation switchChannel switching, measurement mode switching (current data, maximum value, minimum value, runout), parameter setting, presetting, tolerance setting
Input/outputRS Link connectors: 1 each for IN, OUT
Error messageOverspeed, gage error etc.
Power supplyTerminal block (M3 screw), 12 - 24V DC, 200mA
Operating temperature (humidity) range0 to 40°C (RH 20 to 80%, no condensation)
Storage temperature(humidity) range–10 to 50°C (RH 20 to 80%, no condensation)
External dimensions96(W)×48(H)×84.6(D)mm
