Dial Indicators Series 2- Metric Standard Type
Series 2
Series 2 dial indicators are Mitutoyo’s most popular, and have the widest application.
  • Standard 0.01mm graduation dial gauges having an outer frame with an outside diameter of 57mm. All types come with limit pins and an outer frame clamp as standard.
  • The outer clamp and lifting lever (optional) can be attached to either the right or left side. These parts can be easily installed and removed without tools.
  • Secured adhesion between the outer frame and crystal as well as the use of an O-ring ensure countermeasures against water and oil permeation via the front face.
  • The stem spindle is made of high-strength quench-hardened stainless steel which resists strenuous use.
  • A carbide contact point is used.
  • The grand gear uses stainless steel that is resistant to wear and deformation.
  • Application of a hard coating on the surface of the crystal makes the gauge highly scratch- and chemical-resistant.
  • Parts Break Down
Metric
GradRange/ RevDial ReadingOrder NoTypeAccuracyForce
0.015mm/1mm0-1002044Sw/lug0.012mm1.4N or less
0.015mm/1mm0-1002044S-09w/lug0.013mm1.4N or less
0.015mm/1mm0-1002044S-60w/lug0.012mm2.5N or less
0.015mm/1mm0-1002044SBFlat-back0.012mm1.5N or less
0.015mm/1mm0-1002044SB-09Flat-back0.013mm1.4N or less
0.015mm/1mm0-1002044SB-60Flat-back0.012mm1.4N or less
0.015mm/1mm0-50-02045Sw/lug0.012mm1.4N or less
0.015mm/1mm0-50-02045SBFlat-back0.012mm2.5N or less
0.0110mm/1mm0-1002046Sw/lug0.013mm1.4N or less
0.0110mm/1mm0-1002046S-09w/lug0.015mm1.4N or less
0.0110mm/1mm0-1002046S-15w/lug0.013mm0.8N or less*
0.0110mm/1mm0-1002046S-60w/lug0.013mm2.5N or less
0.0110mm/1mm0-1002046S-69w/lug0.015mm2.5N or less
0.0110mm/1mm0-1002046SBFlat-back0.013mm1.4N or less
0.0110mm/1mm0-1002046SB-09Flat-back0.015mm1.4N or less
0.0110mm/1mm0-1002046SB-15Flat-back0.013mm0.8N or less*
0.0110mm/1mm0-1002046SB-60Flat-back0.013mm2.5N or less
0.0110mm/1mm0-1002046SB-69Flat-back0.015mm2.5N or less
0.0110mm/1mm0-1002046SHw/lug0.08mm1.4N or less
0.0110mm/1mm0-1002046SHBFlat-back0.08mm1.4N or less
0.0110mm/1mm0-1002046SLBFlat-back0.013mm1.4N or less
0.0110mm/1mm0-1002046SYw/lug0.013mm1.4N or less
0.0110mm/1mm0-1002046SYBFlat-back0.013mm1.4N or less
0.0110mm/1mm0-50-02047Sw/lug0.013mm1.4N or less
0.0110mm/1mm0-50-02047SBFlat-back0.013mm1.4N or less
0.0120mm/1mm0-1002050Sw/lug0.020mm2.0N or less
0.0120mm/1mm0-1002050S-19w/lug0.020mm2.0N or less
0.0120mm/1mm0-1002050S-60w/lug0.020mm2.5N or less
0.0120mm/1mm0-1002050SBFlat-back0.020mm2.0N or less
0.0120mm/1mm0-1002050SB-19Flat-back0.020mm2.0N or less
0.0120mm/1mm0-1002050SB-60Flat-back0.020mm2.5N or less
0.0130mm/1mm0-1002052Sw/lug0.025mm2.5N or less
0.0130mm/1mm0-1002052S-19w/lug0.025mm2.5N or less
0.0130mm/1mm0-1002052SBFlat-back0.025mm2.5N or less
0.0130mm/1mm0-1002052SB-19Flat-back0.025mm2.5N or less
0.0011mm/0.2mm0-100-02109S-10w/lug0.005mm1.5N or less
0.0011mm/0.2mm0-100-02109S-70w/lug0.005mm1.5N or less
0.0012mm/0.2mm0-100-02109SB-70Flat-back0.005mm1.5N or less
0.0011mm/0.2mm0-100-02109SH-10w/lug0.003mm1.5N or less
0.0011mm/0.2mm0-100-02109SLB-10Flat-back0.005mm1.5N or less
0.0011mm/0.1mm0-1002110S-10w/lug0.005mm1.5N or less
0.0011mm/0.1mm0-1002110SB-10Flat-back0.005mm1.5N or less
0.0011mm/0.1mm0-1002110SB-70Flat-back0.005mm2.0N or less
0.0012mm/0.2mm0-100-02113S-10w/lug0.007mm1.5N or less
0.0012mm/0.2mm0-100-02113SB-10Flat-back0.007mm1.5N or less
0.0015mm/0.2mm0-100-1002118S-10w/lug0.010mm1.5N or less
0.0015mm/0.2mm0-100-1002118SB-10Flat-back0.010mm1.5N or less
0.0015mm/0.2mm0-100-02119S-10w/lug0.010mm1.5N or less
0.0015mm/0.20-100-02119SB-10Flat-back0.010mm1.5N or less
0.0055mm/0.5mm0-502124S-10w/lug0.012mm1.5N or less
0.0055mm/0.5mm0-502124SB-10Flat-back0.012mm1.5N or less
0.0011mm/0.1mm0-1002210S-70w/lug0.005mm2.0N or less
0.0110mm/1mm0-1002310S-10w/lug0.015mm1.4N or less
0.0110mm/1mm0-1002310SB-10Flat-back0.015mm1.4N or less
0.0120mm/1mm0-1002320S-10w/lug0.020mm2.0N or less
0.0120mm/1mm0-1002320SB-10Flat-back0.020mm2.0N or less
0.0130mm/1mm0-1002330S-10w/lug0.025mm2.5N or less
0.0130mm/1mm0-1002330SB-10Flat-back0.025mm2.5N or less
0.0110mm/1mm100-02902Sw/lug0.013mm1.4N or less
0.0110mm/1mm100-02902SBFlat-back0.013mm1.4N or less
0.0130mm/1mm100-02952Sw/lug0.025mm2.5N or less
0.0130mm/1mm100-02952SBFlat-back0.025mm2.5N or less
