Digimatic Caliper Gages Series 209-External Tube Thickness Measurement Type
Series 209
Versatile OD measuring gages for groove thickness, tube thickness, and hard-to-reach dimensions. The Digimatic Caliper Gages provide error-free LCD readings as well as data output for SPC analysis.
 Resolution: .001”, .0005”, or .0002”
0.01mm, 0.02mm, or 0.005mm
Display: Analog / Digital
Power Supply: AAA Battery (2 pcs.)
Battery life: Approx. 350 hours
Measuring Force: 0.8 - 1.7N
Dust/Water protection level: IP67
Provided with inspection certificate.
Zeroset, Preset, Auto power OFF, Inch/Metric conversion,
Data hold, Max/Min value holding, Data output
* Contact type 3, 4 does not have max. min. value hold.
KPL1961-09:SPC Adapter
937387:Digimatic cable (1m)
965013: Digimatic cable (2m)
KPL8004-50:Holder for stand
Inch/Metric
RangeOrder No.ResolutionAccuracy Max.
Measuring
Depth L
Type of Measuring
Contact/type of set up
Measuring
Contact
Length Hb
Measuring
Contact
Length Hf
Mass
0-.39in
0-10mm
209-570.0002in
0.0005mm
.0008in
0.05mm
1.37in
35mm
Ball .059in/ 1.5mm dia. Both/ A.75in
19.1mm
.73in
18.6mm
240g
0-.39in
0-10mm
209-571.0002in
0.005mm
.0004in
0.01mm
1.37in
35mm
Desc .24in/ 6mm dia. Both / C.85in
21.7mm
.58in
14.8mm
175g
0-.78in
0-20mm
209-572.0005in
0.01mm
.001in
0.02mm
3.2in
85mm
Ball .059in/ 1.5mm dia. Both/ A.97in
24.7mm
.97in
24.6mm
280g
0-.78in
0-20mm
209-573.0005in
0.01mm
.001in
0.02mm
3.2in
80mm
Ball .059in/ 1.5mm dia. Both/ B.97in
24.7mm
.10in
2.5mm
270g
0-1.18in
0-30mm
209-913.001in
0.02mm
.002in
0.04mm
4.5in
114mm
Ball .12in/ 3mm dia. Both / A1.17in
30mm
1.17in
30mm
430g
0-1.18in
0-30mm
209-914.001in
0.02mm
.002in
0.04mm
4.58in
116mm
Ball .12in/ 3mm dia. Both / B1.17in
30mm
.16in
4mm
410g
0-1.18in
0-30mm
209-915.001in
0.02mm
.002in
0.04mm
4.56in
116mm
Disc 1.97in/ 50mm dia. Both / D1.42in
36mm
.94in
24mm
430g
0-1.97in
0-50mm
209-918.001in
0.02mm
.002in
0.04mm
6.57in
167mm
30mm
1.17in
30mm
490g
0-1.97in
0-50mm
209-919.001in
0.02mm
.0024in
0.06mm
6.57in
167mm
30mm
.18in
4.6mm
460g
0-1.97in
0-50mm
209-920.001in
0.02mm
.003in
0.08mm
6.57in
167mm
Desc 1.97in/ 50mm dia. Both / D1.42in
36mm
.94in
24mm
500g
