Digimatic Carbon Fiber Caliper- Series 552-with Optional Jaw Attachments
Series 552
Length standard: Electrostatic capacitance type linear encoder
Max. response speed: 1600mm/s
Battery life: Approx. 3,000 hours in continuous use
Origin-set, Zero-setting, Presetting, Offsetting, Data hold, Data output, inch/mm conversion (inch/mm models)
05CZA624:SPC cable with data switch(40in/1m)
05CZA625:SPC cable with data switch (80in/2m)
914055: Centerline attachments (mm)*
914056: Centerline attachments (inch)*
914057: Pointed ID measuring attachments (mm)*
914058: Pointed ID measuring attachments (inch)*
914053: Attachment clamps (for models up to 600mm/24” range)
914054: Attachment clamps (for models over 600mm/24” range)
* Attachment clamps are required and not available for long jaw type.
  • Lightweight Digimatic Calipers that employ CFRP (Carbon Fiber Reinforced Plastics)in the beam and jaws.
  • Highly durable and easy to handle.
  • The range of applications can be expanded by using the optional attachments.
  • Direct readout of ID measurements from the LCD. (Offset value can be set easily by pressing the Offset key.)
  • Preset function for setting a desired starting point.
  • With SPC data output.
  • Special model available with ceramic jaws which are suitable for measuring abrasive
    and magnetic products.
  • Supplied in fitted wooden case.
Order NoImageRangeAccuracy Resolution Remarks
552-312-10552-312-10.jpg0(.5)-18in 0(20)-450mm.002in.0005in 0.01mm-
552-160-10552-160-10.jpg0(.5)-18in 0(20)-450mm.0025in.0005in 0.01mmlong jaws 7.9in
552-165-10-0(.5)-18in 0(20)-450mm.002in.0005in 0.01mmceramic jaws
552-313-10552-313-10.jpg0(.5)-24in 0(20)-600mm.002in.0005in 0.01mm-
552-161-10552-161-10.jpg0(.5)-24in 0(20)-600mm.0025in.0005in 0.01mmlong jaws 7.9in
552-166-10-0(.5)-24in 0(20)-600mm0.002in.0005in 0.01mmceramic jaws
552-314-10552-314-10.jpg0(1)-40in 0(20)-1000mm.002in.0005in 0.01mm-
552-162-10552-162-10.jpg0(1)-40in 0(20)-1000mm.003in.0005in 0.01mmlong jaws 7.9in
552-315-10552-315-10.jpg0(1)-60in 0(20)-1500mm.004in.0005in 0.01mm-
552-163-10552-163-10.jpg0(1)-60in 0(20)-1500mm.0045in.0005in 0.01mmlong jaws 7.9in
552-316-10552-316-10.jpg0(1)-80in 0(20)-2000mm.005in.0005in 0.01mm-
552-164-10-0(1)-80in 0(20)-2000mm.0055in.0005in 0.01mmlong jaws 7.9in
