Digimatic Height Gage Series 192-Multi-Function Type with SPC Data Output
Series 192
  • Highly versatile multi-function type.
  • Carbide-tipped long scriber is provided.
  • Rigid construction ensures repeatable measurement.
  • Coarse/fine feed switching.
  • Bi-directional touch-signal probe is an optional accessory. It can quickly and accurately measure steps, inside width, and outside width.
  • With SPC data output.
Display: LCD, 7-digit
Max. response speed: 500mm/s
Battery: SR44(1pc.), 938882
Battery life: Approx. 2000 hours under normal use
Zero-setting, ABS/INC switching, Presetting, Two presets, Probe tip diameter compensation, -/+ switching, Power ON/OFF, Data hold,
Data output, inch/mm conversion (inch/mm models only)
Standard Scriber Provided
Metric models: Carbide-tipped scriber (905200) and scriber clamp (05GZA033)
Inch/Metric models: Carbide-tipped scriber (905201) and scriber clamp (901385)
905338: SPC cable (40” / 1m)
905409: SPC cable (80” / 2m)
905691: SPC cable (L-shape, 40” / 1m)
905692: SPC cable (L-shape, 80” / 2m)
192-007: Bi-directional touch-signal probe (metric)
192-008: Bi-directional touch-signal probe (inch)
953638: Holding bar for test indicator (length: 50mm)
900209: Holding bar for test indicator (length: 100mm)
953639 Holding bar for test indicator (length: 2”)
900306: Holding bar for test indicator (length: 4”)
900321: Swivel clamp used with holding bar (metric)
900322: Swivel clamp used with holding bar (inch)
Order NumberImageMeasuring RangeResolutionAccuracyMass
192-670-10192-670-10.jpg0-12in 0-300mm.0005in 0.01mm
.0002in(0.005mm)Switchable)]
.001in5.7
192-671-10-0-18in 0-450mm.0005in 0.01mm
.0015in7.5
192-672-10-0-24in 0-600mm.0005in 0.01mm
.0015in8.3
192-673-10-0-40in 0-1000mm.0005in 0.01mm
.0025in15.7
