Digimatic Height Gage Series 192-Standard Type with SPC Data Output
Series 192
 • Switchable resolution (.0002”/0.005mm or.0005”/0.01mm)
 • Easy-to-use standard type.
 • Carbide-tipped scriber is provided.
 • Double-column structure ensures high measuring accuracy.
 • Coarse/fine feed switching.
 • Two preset reference heights.
Display: LCD, 7-digit charter height 11mm
Max. response speed: 500mm/s
Battery: SR44(1pc.), 938882
Battery life: Approx. 2000 hours under normal use
Zero-setting, ABS/INC switching, Two presets,Probe tip diameter compensation-/+ switching,
Power ON/OFF, Data hold,
inch/mm conversion (on inch/mm models only)
Standard Scriber Provided
Metric models: Carbide-tipped scriber (07GZA000) and scriber clamp
( 05GZA033)
Inch/Metric models: Carbide-tipped scriber (07GZA000) and scriber clamp (05GZA033)
and scriber clamp901385)
953638: Holding bar for test indicator (length: 50mm)
900209: Holding bar for test indicator (length: 100mm)
953639: Holding bar for test indicator (length: 2”)
900306: Holding bar for test indicator (length: 4”)
900321: Swivel clamp used with holding bar (metric)
900322: Swivel clamp used with holding bar (inch)
905338:SPC Cable (CD TYPE) 1M
905409:SPC Cable (CD TYPE) 2M
905691:905691 CD/Connecting Cable L-Type 1M RIG
905692:CD/Connecting Cable-L-Type 2M RIG
    Order NumberImageMeasuring Range Accuracy ResolutionMass
    192-630-10192-630-10.jpg0-12in 0-300mm.001.0005in 0.01mm
    .0002in(0.005mm)Switchable]
    4.7kg
    192-631-10-0-18in 0-450mm.002.0005in 0.01mm
    7.5kg
    192-632-10192-632-10.jpg0-24in 0-600mm.002.0005in 0.01mm
    8.3kg
    192-633-10192-633-10.jpg0-40in 0-1000mm.003.0005in 0.01mm
    15.7kg
