Digimatic Micrometer Heads Series 350
Series 350
  • Non-rotating device
    350-261-30,350-361-30
The non-rotating device provides no radial torsion on the workpiece surface so that workpiece wear and deformation are minimized.
Accuracy* ±2ìm Metric model
± .0001" Inch / Metric model
* Excluding quantizing error
Battery: SR44 (1 pc) 938882
Battery life: Approx. 3 years under normal use
350-281-30, 350-382-30, 350-283-30, 350-284-30, 350-261-30
350-381-30, 350-382-30, 350-383-30, 350-384-30, 350-361-30
Preset, inch/mm conversion (inch/mm models)
Function Lock
2 Presets
05CZA662: SPC cable with data switch (1m / 40")
05CZA663: SPC cable with data switch (2m / 80")
Order NoRangeStem/Spindle faceStem dia.Remarks
350-351-300-1in 0-25.4mmPlain/Flat(carbide tip).375in-
350-352-300-1in 0-25.4mmw/clamp nut/Flat(carbide tip).375in-
350-353-300-1in 0-25.4mmPlain/Spherical(SR4).375in-
350-354-300-1in 0-25.4mmw/clamp nut/Spherical(SR4).375in-
350-361-300-1in 0-25.4mmPlain/Flat.5inIP65
350-381-300-1in 0-25.4mmPlain/Flat(carbide tip).5inIP65
350-382-300-1in 0-25.4mmw/clamp nut/Flat(carbide tip).5inIP65
350-383-300-1in 0-25.4mmPlain/Spherical(SR4).5inIP65
350-384-300-1in 0-25.4mmw/clamp nut/Spherical(SR4).5inIP65
