Digimatic Scale Units Series 572-With Dust/Water Protection IP66 Level
Series 572
  • Newly employed detection method (Electromagnetic induction method) enables use in adverse environments with water and cutting oil.
  • Specially designed output cables are developed to maintain the water resistant structure.
  • No over speed error since it employs absolute scale which reads the absolute value.
  • Once an absolute zero (origin) point is set, the Digimatic Scale Unit shows its absolute distance from the point whenever turned on rather than 0.00”.
Repeatability: 0.01mm
Length standard: ABSOLUTE electromagnetic induction linear
encoder
Battery life: Approx. 1.5 years under normal use
Dust/Water protection level: IP67
Origin-set, Zero-setting, Automatic power on/off, Data
output, inch/mm conversion (inch/mm models)
05CZA624: SPC cable with data switch (1m / 40”)
05CZA625: SPC cable with data switch (2m / 80”)
IP (International Protection) Codes:
Example, IP66 mean:
1st Digit “6”:Dust sealing
2nd Digit “6”:Water resistant
Order NoModelRangeAccuracy ResolutionBattery LifeType
572-613SD-4"/10G0-4in 0-100mm.001in0.03mm.0005in 0.01mmApprox.13,000 hrsHorizonal single-function type (water-proof)
572-614SD-6"/15G0-6in 0-150mm.001in0.03mm.0005in 0.01mmApprox.13,000 hrsHorizonal single-function type (water-proof)
572-615SD-8"/20G0-8in 0-200mm.001in0.03mm.0005in 0.01mmApprox.13,000 hrsHorizonal single-function type (water-proof)
