Digimatic Tubular Inside Micrometers-Series 337-Extension Rod Type/Series 339-Extension Pipe Type
Series 337
  • Wide range of ID measurements by combining extension rods (pipes) and anvils with the micrometer head.
  • The 339 series uses highly-durable extension pipes.
  • Carbide-tipped measuring faces.
Accuracy: ±(3+n+L/50) µm*
* n=Number of rod, L=Maximum measuring length (mm), Fraction rounded up, Excluding quantizing error (337 series)
Resolution: 0.001mm or .0001"/0.001mm
Battery: SR44 (1 pcs.), 938882
Battery life: Approx. 8 months under normal use
Zero-setting, Data hold, Data output, Preset, inch/mm conversion (inch/mm models)
Optional Accessory
05CZA662: SPC cable (1m)
05CZA663: SPC cable (2m)
Order NoImageRangeHead Travel Extension Rods
337-102-8-9in-
203.2-228.6mm
1in-
337-303337-303.jpg8-40in-
203.2-1016mm
1in1, 2, 4,(2pcs.) 8, 12 in.
337-304337-304.jpg8-60in-
203.2-1524mm
1in1, 2, 4, 8, 12 in.(3pcs)
339-102339-102.jpg8-9in-
203.2-228.6mm
1in-
339-303339-303.jpg8-40in-
203.2-1016mm
1in1,2,4,8,16 in
339-304339-304.jpg8-80in-
203.2-1524mm
1in1,2,4,8,(2pcs),16in(3pcs)
