Digital Height Master Series 515
Series 515
  • Standard model with a digital display, featuring all essential specifications required for versatile height standard.
  • With SPC output.
  • Each Height Master is supplied with a gage block for zero setting.
Resolution (LCD): .0001" or 0.001mm
Graduation: .0001" or 0.002mm
Character Height .21" / 5.4mm
Micrometer Head
Travel Stroke: 1" or 20mm
Pitch: .025"/rev or 0.5mm/rev
Hystersis: .0001" For all inch models
0.002mm for 300mm models
0.0025mm for 450 & 600mm models
Battery: SR44 (2 pcs.), 938882
Battery life: Approx. 1.8 years under normal use
Zero-setting, Presetting, ABS/INC switching, Data hold, Data
output, inch/mm conversion (inch/mm models)
Standard Accessories
Reference Block: 11mm for Metric Height Master 611621-031
Reference Block: .6" for for Inch Height Master 611196-531
Provided with inspection certificate.
515-111: Auxiliary block kit for bore gage (mm)
515-120: Auxiliary block kit for bore gage (inch)
959149: SPC cable (40” / 1m)
959150: SPC cable (80” / 2m)
050019: Fitted Mohogany case for 12” / 300mm model
050059: Fitted Mohogany case for 18” / 450mm model 24" / 600mm model
InchMetric
Order No515-375515-377515-379
Range.5-12".5-18".5-24"
Block Step1"(staggered)1"(staggered)1"(staggered)
LCD Resolution .0001"/ 0.001mm.0001"/ 0.001mm.0001"/ 0.001mm
Block Pitch Accuracy.0001.0001.0001
Block Parallelism .00005".0001".0001"
Micrometer Head Accuracy.0001" .0001" .0001"
Mass20.9lbs29.9lbs35.2lbs
