EV Counter-Multi-function,Multiple Input Type Series 542
Series 542
Processor (Optional Display), Multi-function/output
  • Up to six gages can be connected to one unit, extendable up to 10 units (60 gages at maximum) using the RS Link function* to facilitate the configuration of a multi-point measurement system. * Refer to "Quick Guide to Precision Measuring Instruments" on page G-32 for details of the RS link.
  • A range of output modes to choose from: I/O output for tolerance judgment and segment output, BCD data output and RS-232C output are available.
  • Other than normal measurement, peak measurement or differential measurement between gages are available.
  • External Control (Zero-set, Preset etc.)
  • Direction switch
  • Error display
  • Tolerance judgment output
  • Diverse data output (RS-232C, BCD, Segment)
  • Peak measurement Maximum value, minimum value, runout, and differential measurement between two gages Addition, averaging, maximum value, minimum value, and maximum width
  • D-EV External display unit: No.02ADD400
  • SPC cable (0.5m): No.02ADD950
  • SPC cable (1m): No.936937
  • SPC cable (2m): No.965014
  • AC adapter: No.02ADN460*
  • AC cable (USA): 02ZAA010*
  • Terminal connecting cable: No.02ADD930*
    * Included in package Order No.
LED display: 8 digits for parameter display (displays settings), 1 for error display
Error message: Overspeed, gage error etc.
External display: Dedicated external display unit D-EV (optional) can be connected.
Function of input switches: Measurement mode switching, parameter setting
Input/ output Tolerance judgment output 1 to 6 channels (L1, L2, L3), open-collector BCD output Parallel BCD output (positive/negative-true logic), open-collector Segment output Function to set on only the terminals corresponding to the counting values, open-collector Control output Normal operation signal (NOM), open-collector Control input Output channel designation (segment, in the BCD mode), presetting, peak value clear, range changeover (at segment output), holding counting value open-collector or no-voltage contact signal (with/without contact point)
Interface
RS-232C:
Measurement data output and control input
EIA RS-232C-compatible Use cross cables for home position, DTE (terminal definition).
RS link:
Max. connecting unit: 10 (6 when using EF counter)
Connecting cable length: Max. 10m (sum of link cable length)
Data transfer time: 1sec./60ch (when transmission rate is 19200bps)
Rating:
Power supply voltage: 12 - 24V DC, terminal block (M3 screw)
Power consumption: 8.4W or less (700mA max.) Ensure at least 1A is available per unit.
Operating temperature:(humidity) range 0 to 40°C (RH 20 to 80%, no condensation)
Storage temperature:(humidity) range –10 to 50°C (RH 20 to 80%, no condensation)
External dimensions: 144 (W) × 72 (H) ×139 (D) mm
Order No542-063542-067542-064
Package No. (counter w/AC adapter64PKA13764PKA13964PKA138
Applicable inputDifferential square-waveDifferential square-waveDigimatic code (SPC)
Applicable gageLGE, LGF, LGK, LGB, LGM, LG
not compatible with reference point mark,
sine wave output type or 0.1µm resolution models
LGF with origin point markLGD, LGS
No of input channels666
Resolution.000005, .00005, .0005in 0.0005, 0.001, 0.005, 0.01mmmm.000005, .00005, .0005in 0.0005, 0.001, 0.005, 0.01mmmm.00005*, .0005in 0.001*, 0.01mmmm
Mass910g910g830g
line drawings product manuals
