FALCIO Apex 2000/3000 Series 355 High Accuracy Large CNC CMM
Series 355
This giant CNC CMM provides a huge measuring range of 80” x 120” x 60” (2000mm x 3000mm x 1500mm) to 120” x 200” x 80” (3000mm x 5000mm x 2000mm).
Length standard: High accuracy linear encoder
Guide system: Air bearing
Max. drive speed: 430mm/sec
Max. acceleration: 0.17G
Air pressure: 0.4MPa
Air consumption: 120L/min
* The machine is equipped with the temperature compensation system.
Conformed standard: ISO10360-2 L: Measuring length (mm)
Model No.FALCIO Apex G 203015FALCIO Apex G 204015FALCIO Apex G 205015FALCIO Apex G 305015
X-Axis0-78.94in 0-2005mm0-78.94in 0-2005mm0-78.94in 0-2005mm0-118.31in 0-3005mm
Y-Axis0-118.31in 0-3005mm0-157.68in 0-4005mm0-197.05in 0-5005mm0-197.05in 0-5005mm
Z-Axis0-59.25in 0-1505mm0-59.25in 0-1505mm0-59.25in 0-1505mm0-59.25in 0-1505mm
Resolution .000004in 0.0001mm.000004in 0.0001mm.000004in 0.0001mm.000004in 0.0001mm
AccuracyE-(4.8+5L/1000)µm
R-5µm
E-(4.8+5L/1000)µm
R-5µm
E-(4.8+5L/1000)µm
R-5µm
E-(5.5+5L/1000)µm
R-5µm
Mass (main unit)26455lbs 12000kg30864lbs 14000kg33069lbs 15000kg35273lbs 16000kg
