Formtracer SV-C3200 / SV-C4500 Series 525-Surface Roughness / Contour
Series SV-C series
  • Dramatically increased drive speed (X axis: 3.1”/s (80 mm/s), Z2 axis column: .78”/s (20 mm/s) further reduces total measurement time.
  • In order to maintain the traverse linearity specification for an extended period of time, Mitutoyo has adopted highly rigid ceramic guides that combine the characteristics of smallest secular change and remarkable resistance to abrasion.
  • The drive unit (X-axis) and column (Z2- axis) are equipped with a high-accuracy linear encoder (ABS type on Z2-axis). This improves reproducibility of continuous automatic measurement of small holes in the vertical direction and repeated measurement of parts which are difficult to position.
Model No.SV-C3200S4SV-C3200H4SV-C3200W4SV-C3200S8SV-C3200H8SV-C3200W8SV-C3200L4
Order No (inch)525-491-11A525-492-11A525-493-11A525-496-11A525-497-11A525-498-11A525-494-11A
Image-------
X1-axis measuring range4in 100mm4in 100mm4in 100mm8in 200mm8in 200mm8in 200mm4in 100mm
Measuring force of detector0.75mN0.75mN0.75mN0.75mN0.75mN0.75mN0.75mNmN
Vertical travel power column12in 300mm20in 500mm20in 500mm12in 300mm20in 500mm20in 500mm27.6in 700mm
Granite base size (wxd)23.6x17.7in 600x450mm23.6x17.7in 600x450mm39.4x17.7in 1000x450mm23.6x17.7in 600x450mm23.6x17.7in 600x450mm39.4x17.7in 1000x450mm39.4x17.7in 1000x450mm
Dimensions (main unit WxDxH)39.6x22.6x38.0in
(996x575x966mm)
39.2x22.6x46.3in
(996x575x1176mm)
55.4x22.6x46.3in
(1396x575x1176mm)
39.6x22.6x38.0in
(996x575x966mm)
39.2x22.6x46.3in
(996x575x1176mm)
55.4x22.6x46.3in
(1396x575x1176mm)
45.5 x 19.0 x 56.5"
(1156 x 482 x 1436mm)
Mass(main unit)308lbs 140kg330lbs 150kg485lbs 220kg308lbs 140kg330lbs 150kg485lbs 220kg595lbs 270kg
Pages: 1    2    3
videos literature
