Gear Tooth Micrometers - Series 324, 124 Interch. Ball Anvil Type
Series 324
  • IP65 water/dust protection (324 series).
  • Measures over-pin diameter of gears with precision steel (carbide) ball-tipped measuring faces.
  • With a standard bar except 0-25mm and 0-1” model
  • Interchangeable ball anvil-spindle tips for various gear modules (0.5 - 5.25) are optional.
  • With SPC output (Series 324).
  • Supplied in fitted plastic case (models over 150mm supplied in wooden case).
Accuracy: Refer to the list of specifications
Resolution*:0.001mm or .00005"/0.001mm
Graduation**: 0.01mm
Display*: LCD
Battery life*: Approx.1.2 yrs under normal use
Dust/Water protection level*: IP65
Function of Digital Model
Zero-setting, Data hold, Data output, Preset, inch/mm
conversion (inch/mm models)
Function Lock
2 Presets
05CZA662: SPC cable with data switch (1m / 40”)*
05CZA663: SPC cable with data switch (2m / 80” )*
*Only for digital models
AnvilsInch/MetricMetric
Order NumberDiameterGear moduleDIA Pitch
124-8010.8mm0.5-0.5550
124-8021mm0.6-0.6545
124-8031.191mm(3/64in)0.7-0.835-30
124-8041.588mm(1/16in)0.9-128-26
124-8052mm1.2522
124-8062.381mm(3/32in)1.517
124-8073mm1.7515
124-8083.175mm(1/8in)---14
124-8093.969mm(5/32in)213
124-8104mm2.2511
124-8114.763mm(3/16in)2.510
124-8125mm2.759
124-8135.556mm(7/32in)3.0-3.258
124-8146mm3.57
124-8156.35mm(1/4in)3.757
124-8167mm4.06.5
124-8177.144mm(9/32in)4.256
124-8187.938mm(5/16in)4.55.5
124-8198mm4.755.5
124-8208.731mm(11/32in)5.0-5.255
124-8211.5mm0.9-128-26
124-8222.5mm1.517
124-8233.5mm213
124-8244.5mm2.510
