HM-210/220 Series 810- Micro Vickers Hardness Testing Machines
Series 810
  • The electromagnetic force motor used in the loading mechanism enables the test force to be freely selected (see test force specifications) over the wide range of 0.4903mN to 19610mN (0.05gf to 2 kgf). It is also possible to freely set load dwell times. Now your desire for absolute control over the indentation size in Vickers hardness testing can be satisfied. The HM-200 series always offers the test force most appropriate for the specimen material and shape.
  • The long working distance objectives used enable a very comfortable working distance between the objective and the specimen surface. This, greatly reduces the possibility of collision between the specimen and the objective during focusing operations. (e.g. for 50X objectives: 1.1mm for conventional models, 2.5mm for HM-200 series)
  • Newly-designed ‘MH Plan’ objectives are optimized for measuring indentation images. The lineup includes 6 types of long working distance objectives: 10X, 20X, 50X and 100X for measuring indentation images, and 2X and 5X for enabling wide-range measurement around indentations.
  • LEDs, which have a longer life, produce less heat, consume less power and are more energy efficient than incandescent bulbs, are employed for the illumination system.
  • The motorized turret allows for up to 4 objective lenses and 2 indenter assemblies to be mounted at the same time.
      Test force range:
      HM-210A: 9 steps + arbitrary test force
      HM-220A: 19 steps + arbitrary test force
      Load dwell time: 0 - 999s
      Manual XY stage unit
      Stage size: 100x100mm
      Travel range: 25x25mm
      with Digimatic in/mm micrometer heads
      Resolution: 0.001mm
      Max. specimen height: 133mm (Stage size: 25 x 25mm)
      Max. specimen height: 121mm (Stage size: 50 x 50mm)
      Max. specimen depth: 160mm (from the center of indenter)
      Optical path: 4-port objectives switching system of Infinity-correction optical system
      Resolution: 0.01μm (When using objectives of X40 or more)
      Data output: Serial interface (RS-232),
      Digimatic interface, USB 2.0
      Power supply: 39VA 100-125/220-240V AC, 50/60Hz
      Dimensions: (W x D x H): 315x671x595mm
      Mass: 43kg
      Optional Accessories (Factory-installed option)
      11AAC104: Objective lens unit 2X
      11AAC105: Objective lens unit 5X
      11AAC106: Objective lens unit 10X
      11AAC107: Objective lens unit 20Xv 11AAC108: Objective lens unit 100X
      11AAC129: Measuring microscope (Digital ocular)
      11AAC109: Knoop Indenter Assembly (HM-210 Series)
      11AAC110: Knoop Indenter Assembly (HM-220 Series)
      810-354A: TV camera unit (8.4 inch LCD)
      19BAA058: Diamond indenter for Vickers
      (HM210 Series standard test force)
      19BAA059: Diamond indenter for Vickers
      (HM220 Series low test force)
      19BAA061: Diamond indenter for Knoop (HM210 Series)
      19BAA062: Diamond indenter for Knoop (HM220 Series)
      810-017: Vise
      810-013: Specimen (thin plate) holder
      810-014: Specimen (wire) holder
      810-015: Specimen (wire or ball) holder
      810-019: Specimen tilting holder
      810-020: Universal specimen holder
      810-018: Rotary table
      810-084: Rotatable universal specimen holder
      810-085: Adjustable specimen (thin plate) holder
      810-095: Rotatable specimen stage
      375-056: Stage Micrometer (glass) Micro-scale
      810-650-1: Resin mold specimen stage ø25.4
      810-650-2: Resin mold specimen stage ø30
      810-650-3: Resin mold specimen stage ø31.75
      810-650-4: Resin mold specimen stage ø38.1
      810-650-5: Resin mold specimen stage ø40
      02ATE760: Table
      810-641: Vibration Isolator
      810-870A: Sample Heating Device HST-250
      810-420: 25x25mm stage (metric only)
      810-423: 50x50mm stage (metric only)
      810-424: 1”x1” in/mm stage (standard)
      810-427: 2”x2” in/mm stage
       PC is optional
TYPE A-Digital Hardness Tester
TYPE B-PC Driven Test System
TYPE D-PC Driven Test System with motorized stage and auto focus
System D Technical Data
Motorized X-Y Stage
Travel Max
50 x 50 mm
Travel Min
Table Size
130 x 130 mm
Speed Max
25 mm/ sec
Motorized Focusing Stage
Max Range
1.4 mm
Min Unit
.1µ
Max Speed
1 mm/ sec
Joystick Controller Functions
Functions
X and Y Lock out
Axis
X,Y and Z (Focus)
Speed Control
Adjustable H,M,L
Tester Control
Indent, Turret Position
Other
Emergency Stop
Type AType BType D
Model No.HM-210 Type AHM-210 Type A V/KHM-220 Type AHM-220 Type A V/K
Part No.64AAB305P64AAB306P64AAB307P64AAB308P
Image_210A-220A-HM-TV-Montior.jpg---
Main Unit No.810-400810-400810-405810-405
Fixed test force (mN)98.07, 196.1, 294.2, 490.3, 980.7, 1961, 2942,4903, 9807 (10gf-1000gf)98.07, 196.1, 294.2, 490.3, 980.7, 1961, 2942,4903, 9807 (10gf-1000gf)0.4903, 0.9807, 1.961, 2.942, 4.903, 9.807, 19.61,29.42, 49.03, 98.07, 196.1, 294.2, 490.3, 980.7,1961, 2942, 4903, 9807, 19610 (0.05 gf-2kgf)0.4903, 0.9807, 1.961, 2.942, 4.903, 9.807, 19.61,29.42, 49.03, 98.07, 196.1, 294.2, 490.3, 980.7,1961, 2942, 4903, 9807, 19610 (0.05 gf-2kgf)
Arbitrary test force≤100 gf in 1 gram increments, > 100gf in 10 gram increments≤100 gf in 1 gram increments, > 100gf in 10 gram increments< 1 gf in .1 gf increments, ≤100 gf in 1 gram increments, > 100gf in 10 gram increments< 1 gf in .1 gf increments, ≤100 gf in 1 gram increments, > 100gf in 10 gram increments
Test force controlForce generation by electromagnetic and automatic control (load, dwell, unload)Force generation by electromagnetic and automatic control (load, dwell, unload)Force generation by electromagnetic and automatic control (load, dwell, unload)Force generation by electromagnetic and automatic control (load, dwell, unload)
Control unitColor LCD Touch ScreenColor LCD Touch ScreenColor LCD Touch ScreenColor LCD Touch Screen
Loading Rate60µ/ sec60µ/ sec60µ/ sec60µ/ sec
Load Dwell Time0-999 sec0-999 sec0-999 sec0-999 sec
IndenterVickersVickers and KnoopVickersVickers and Knoop
Objective Lens10x, 50x10x, 20x, 50x10x, 20x, 50x10x, 20x, 50x
Objective turretMotor driven and manual operationMotor driven and manual operationMotor driven and manual operationMotor driven and manual operation
Filar Eye PieceDual Line, 10X, .01µ minDual Line, 10X, .01µ minDual Line, 10X, .01µ minDual Line, 10X, .01µ min
videos
