HR-521 (L) /523 (L) Series 810-Rockwell Type Hardness Testing Machines
Series 810
  • Multiple test force generation for
    Rockwell, Rockwell Superficial and Brinell hardness.
  • Dolphin-nose indenter arm for easy reach of interior (min. ø40mm/ø22mm*) and exterior surfaces. *When using an optional diamond indenter (19BAA292).
  • Real time electronic test force control for accurate loading. This perfectly eliminates load force overshooting.
  • Indenter escape function for continuous testing at fixed table position. This eliminates instability caused by the table retraction.
  • Auto-stop elevation table and automatic preliminary test force loading to provide stable test force generation.
  • Complete with one flat and VEE anvil, diamond and 1/16” carbide ball indenters, 2 HRC and 1 HRBW Rockwell test blocks and an HR30N and HR30TW test block.
Preliminary test force: 29.42N, 98.07N
Test force
Rockwell superficial: 147.1, 294.2, 441.3N
Rockwell: 588.4, 980.7, 1471N
Brinell*: 61.29, 98.07, 153.2, 245.2, 294.2,306.4,
612.9, 980.7, 1226, 1839N
Test force setting: By control unit
Load control: Automatic
(loading, duration, unloading)
Load duration: 0s - 120s (1s increments)
Max. specimen height: 205mm (for standard flat anvil)
Max. specimen depth: 150mm
(from the center of indenter shaft)
Stage elevation: Manual or power drive
Control unit: Sheetswitch type or touch screen type
Data output: RS-232C, Digimatic code (SPC) and
Centronics
Power supply: 120V AC, 50/60Hz
Dimensions (W x D x H)
Main unit: 250 x 670 x 605mm
Control unit: 165 x 260 x 105mm
Order Number810-202-03A810-205-03A
Model NumberHR-521HR-521L
Prelimiary Test Force29.42N(3kgf)
98.07N(10kgf)
29.42N(3kgf)
98.07N(10kgf)
Test Force Rockwell 588.4N (60kgf), 980.7N (100kgf), 1471N (150kgf)
Rockwell Superficial 147.1N (15kgf), 294.2N (30kgf), 441.3N (45kgf)
Specimen Depth 5.9in-150mm5.9in-150mm
Dimension 9.84x26.38x23.82in 250x670x605mm-
DisplayTouch screen operation with back-lit LCD graphic display-
DriveManual (w/Auto-brake mechanism)-
Max. Specimen Height 8.1in-205mm15.5in-395mm
Mass132lbs 60kg-
OutputRS-232C, SPC, Centronics-
Load Duration Range 0/s min-120s/ max s/ increment-
Pages: 1    2
