HV110 / HV120 Series 810-Vickers Hardness Testing MAchines -Type A
Series 810
Vickers Hardness Testing Machines – Type A
  • Heavy load Vickers testing machines feature motorized force selection from 1-50kgf or .3 to 30kgf. Fully adjustable long-life LED illumination runs cool.
  • A dual-line filar eyepiece combines with a color touch-screen LCD to create accurate measurements with the touch of a button.
  • The motorized turret can accommodate up to 3 long working distance objective lenses for an even wider range of materials and a wide variety of anvils and x-y stages are also available.
Lens:
11AAC712 OBJECTIVE LENS 2X
11AAC713 OBJECTIVE LENS 5X
11AAC714 OBJECTIVE LENS 20X
11AAC715 OBJECTIVE LENS 50X
11AAC716 OBJECTIVE LENS 100X
Stage
810-423 MANUAL STAGE 50X50
810-427 MANUAL STAGE 2”X 2”(In/mm)
959149 SPC cable (1m / 40”)
Optical
11AAC711 “C” mount CAMERA ADAPTER
810-454A CCTV System
Indenters
19BAA060 DIAMOND INDENTER (VICKERS TYPE)
19BAA063 KNOOP DIAMOND INDENTER
19BAA281 CARBIDE-ALLOY BALL 1MM DIA.
19BAA277 CARBIDE-ALLOY INDENTER, 1MM DIA.
19BAA283 CARBIDE-ALLOY BALL, 2.5MM DIA.
19BAA279 CARBIDE-ALLOY INDENTER, 2.5MM DIA.
Additional Test Force
11AAC697 0.5 kg Brinell Weight
11AAC698 1.25 kg Brinell Weight
11AAC699 5.625 kg Brinell Weight
11AAC700 12.5 kg Brinell Weight
*Optional test forces ma be required
Model NumberHV110HV120
Order Number810-440A810-445A
Test Force9.807N (1kgf),19.61N (2kgf),29.42N (3kgf), 49.03N (5kgf), 98.07N (10kgf), 196.1N (20kgf)294.2N (30kgf), 490.3N (50kgf)2.942N (0.3kgf),4.903N (0.5kgf), 9.807N (1kgf),24.51N (2.5kgf),49.03N (5kgf), 98.07N (10kgf), 196.1N (20kgf)294.2N (30kgf)
Supported test methodHV, HK, HB (Light Force*), KcHV, HK, HB (Light Force*), Kc
Test force selectionMotorizedMotorized
Loading Accuracy ±1%±1%
Load Control60µ/s, 150µ/s Automatic (loading, duration, unloading)60µ/s, 150µ/s Automatic (loading, duration, unloading)
Load Rate5~999 sec.5~999 sec.
Objective lens2X, 5X, 10X (standard), 20X, 50X, 100X2X, 5X, 10X (standard), 20X, 50X, 100X
Measuring microscope10X Dual-line filar10X Dual-line filar
Total magnification20-1000X (100X Standard)20-1000X (100X Standard)
Field of view1,400µ (10X Lens) Type A1,400µ (10X Lens) Type A
Minimum reading< 50x = 0.1µm, =50x = 0.01µm< 50x = 0.1µm, =50x = 0.01µm
Display Color LCD touch-screenColor LCD touch-screen
Scaled conversion8 Types (ASTM, ISO, JIS, SAE and BS)8 Types (ASTM, ISO, JIS, SAE and BS)
StatisticsN, Max., Min., Average, Range, High, Low, Good, Over, Under, SD(n-1), SD(n-1), SD(n) go/no-go judgmentN, Max., Min., Average, Range, High, Low, Good, Over, Under, SD(n-1), SD(n-1), SD(n) go/no-go judgment
Curvature correction0.01 to 200.00mm0.01 to 200.00mm
Maximum sample height210mm Type A210mm Type A
Maximum sample depth160mm160mm
Maximum sample weight20 Kg Anvil, 10 Kg with x-y Stage20 Kg Anvil, 10 Kg with x-y Stage
Optical path100% Eyetube or Camera100% Eyetube or Camera
OutputRs232, SPC, USB2.0Rs232, SPC, USB2.0
Power supply120 Volt AC/ 60 Hz120 Volt AC/ 60 Hz
Dimensions main unit (WxDxH)9.9”x 24.7”x30.7 “ (252x627x781mm)9.9”x 24.7”x30.7 “ (252x627x781mm)
Mass110lbs. (50kg)110lbs. (50kg)
literature
